8T 2.0
#782
I was also told by a buddy that the servo saver arms are breaking. He said 4 went down last weekend at the track. Just to be on the safe side I bought the AL servo saver arm.
http://www.amainhobbies.com/product_...ducts_id/30453
#786
If the rims are hitting the rods these wil be the ticket to solving the problem
http://www.amainhobbies.com/product_...oducts_id/6047
mzl Hellsavage
mzl Hellsavage
#787
i watched one fail Touching the pipe...its not a "being set properly" issue.
i would suggest installing the alum version before the first run...whats the point of having to take off the front end and screw with the saver the first day at the track.
#788
I still agree that the aluminum upgrade is a good one but don't see why the plastic ones would be breaking.
#789
mzl Hellsavage
mzl Hellsavage
#791
About the servo saver arm breaking I had it happen to me on the buggy and also lost a servo when it happened
the problem is the servo saver cant move as far as it needs to when its set from the factory it will only move about 1/4 the way down the ramp
the fix just back off the servo saver about 3 or 4 turns till it moves about 3/4 down the ramp that should fix it
also I wouldnt use the alum servo arm untill you loosen the servo saver better to break the arm than a servo I have also seen them break the whole right side of the servo saver
#792
Ill state it again...these were all rebuilt by myself and tested...they had more then enough throw to do their job...i didn't even question putting on the new 2.0 plastics as i knew the saver actually worked...yett they broke...and to the user who claimed the 1.0 alum top worked on the 2.0 bottom is sadly mistaken...then do not line up worth a bean and i couldn't see the saver actually working like that.
#793
#794
