8T 2.0
Old 05-18-2010 | 10:25 AM
  #7291
token's Avatar
Originally Posted by Muggydude
Quick Q on setting camber. If I drop my truck from a foot up 4 times, and measure the angles of the wheels each time, I get different measurements. How do I set the camber?
The absolute best way is to use a set up system. But I was taught here buy a local pro not to drop, just push down on the truck and let it rebound, then do the camber.....
token is offline
Old 05-18-2010 | 10:28 AM
  #7292
builtb16a's Avatar
clutch shoe questions...
do springs wear out? and at what point do you change shoes? is there a measurement?
ive heard losi long wear shoes, and 2 green and 2 black springs. anyone's preference?
builtb16a is offline
Old 05-18-2010 | 11:17 AM
  #7293
token's Avatar
Yes they wear out, and to be honest I never measured my shoes, I just replace them when I feel a lot of slipping or by look never had a problem doing it that way....
I run dyn Maxlife shoes - similar to losi LL, and gold and silver springs, really like that setup..
token is offline
Old 05-18-2010 | 11:20 AM
  #7294
l3asher's Avatar
Yes the springs do wear out. Here ya go from the other thread.
Measure 23.4, any thing less is a worn out. Thanks, Nick for the pic.
l3asher is offline
Old 05-18-2010 | 03:46 PM
  #7295
Hate2Looz's Avatar
I have found that as long as you are consistant in the manner that you check your ride height and camber, all is well. The problem with the drop
method, that I don't like, is that unless you have an exact measurement of
the drop, you will get inconsistant readings. I push the car/truck down evenly, in the center of the front and rear towers before my measurements.
Never failed me yet and very consistant as far as repeatability(if thats even
a word, lol). Plus, I like to see how the shocks are working, rebound-wise. If
you've ever been burned by a sticky shock shaft o-ring/seal you'd understand why.
Now, if I could only find an exact way to set front toe, without
a Hudy station, I'd be perfectly happy. I'm good with just eyeballing it for
now though.
Hate2Looz is offline
Old 05-19-2010 | 04:11 PM
  #7296
losi_racer's Avatar
finally , de racing mud guards for truggy
http://www.neobuggy.net/modules/news...p?storyid=8227
losi_racer is offline
Old 05-19-2010 | 04:20 PM
  #7297
JAMMINKRAZY's Avatar
Yaaaaaaaaaaaaay Finally!
JAMMINKRAZY is offline
Old 05-19-2010 | 04:23 PM
  #7298
teamlosi906's Avatar
Default de
cool just ordered mine
teamlosi906 is offline
Old 05-19-2010 | 04:42 PM
  #7299
losi_racer's Avatar
me too, got a set for buggy and truggy
Old 05-19-2010 | 05:45 PM
  #7300
bigjayjay1's Avatar
Opps
bigjayjay1 is offline
Old 05-19-2010 | 10:57 PM
  #7301
andre lim's Avatar
HI, I got the losi 8T 1.0 and planning to get the 8T 2.0.
Does they share the same parts?
andre lim is offline
Old 05-19-2010 | 11:26 PM
  #7302
dnebout's Avatar
Anybody have a lead on Losi shock foams for the shock mod. I haven't seen anything yet. last I heard was May arrival.
dnebout is offline
Old 05-20-2010 | 01:01 AM
  #7303
Bigedmond's Avatar
Crap. I have been measuring in the wrong spot. If i measure that spot, its like 21.8
Bigedmond is offline
Old 05-20-2010 | 04:42 AM
  #7304
pballer2777's Avatar
last i saw was late. which probably means mid june.
pballer2777 is offline
Old 05-20-2010 | 06:10 AM
  #7305
token's Avatar
a few. the 2.0 is wider and longer
token is offline
