8T 2.0
Old 05-02-2010 | 12:02 PM
  #6901
JAMMINKRAZY's Avatar
Originally Posted by l3asher
I have been running aka with stock hexs and I can deal with a little rubbing. My problem is I want to run calibers and you have to use the proline rims. Should I let them rub or run the +2? What are the pros and cons? Do I run the +2 all the way around?
I run the +2's just in the front. They stop the rubbing which is a huge thing for me. I don't like allowing the webbing to rub at all. It can cause the wheel to lock up, and that's not good for a consistent feeling on the track.
JAMMINKRAZY is offline
Old 05-02-2010 | 12:12 PM
  #6902
jwcobra03's Avatar
Shannon, i run the +2mm all the way around. You seen me run many times and i don't see any problems with them.
jwcobra03 is offline
Old 05-02-2010 | 12:33 PM
  #6903
Hey guys,
Got a question for you guys. I have an 8t and enjoy the crap out of it. But my only problem with it is ive been going through servos faster than fuel. At last weeks race I chewed up 3 servos, one ace 1015, one futaba Brushless 352 and one of my friends . Now today I started it just to fire it up and the 4th one went out with out hitting anything!!! I just need help oh this guys anything would be nice thanks!!! Has this happend to anyone? please feed back.
Beenbreto is offline
Old 05-02-2010 | 01:30 PM
  #6904
l3asher's Avatar
Originally Posted by Beenbreto
Hey guys,
Go Hitec set your end points and never look back Hitec 7955.
l3asher is offline
  #6905
l3asher's Avatar
Any cons?
l3asher is offline
Old 05-02-2010 | 01:57 PM
  #6906
Any cons?
Not any that I have noticed. I almost feel like they give the truck a bit more steering. Could be because the wheels don't rub.
Old 05-02-2010 | 02:27 PM
  #6907
Slider30250's Avatar
Originally Posted by MaSt
Can you comment my driving. Here is the video
I know that i have some driving issues. In the video you can see that it was sunny, but actually it chill and windy (cameraman almost dropped camera because of the coldness)
Your driving is really not that bad for just a practice run, show us a video of you during a race if you really want to know how your driving is.
Slider30250 is offline
Old 05-02-2010 | 02:29 PM
  #6908
bobbyblaze's Avatar
Hey guys,
and if its throttle servo its a must you go by the ademdom sheet thag came with your manual
bobbyblaze is offline
Old 05-02-2010 | 05:30 PM
  #6909
Frank L's Avatar
Hey guys,
Look at where the servo sits near the chassis and make sure its not rubbing against the plastic side mud guard. That contact will be enough to blow servos. I went through 5 or 6 before a Losi team driver pointed it out, since then no throttle servo issues. And the 7955, 7950 or 7940 will get the job done forever.
Heres what I ended up doing to the mud guard.
Any cons?
I run the +2 hexes and performance gain was negligible. But the wheels do not rub anymore thats a plus.
Frank L is offline
Old 05-02-2010 | 05:32 PM
  #6910
pballer2777's Avatar
Hey guys,
set your end points. use spacers if the book tells u to. also take notice how far away the servo is to the mud gaurds. i blew a servo and the case was up against the mud gaudrs. so with a dremel i trimed out the lip between the mounting screws where the servo sits. so far no problems. also make sure u use the rubber gromets that come with the servo.
pballer2777 is offline
Old 05-02-2010 | 05:49 PM
  #6911
tc5 man's Avatar
is this servo issue rubbing on mud, guard only a issue with the 2.0 ? than again i do run a radio tray stiffner, and rubber spacers under the servo. i never blew a throttle servo
tc5 man is offline
Old 05-02-2010 | 08:54 PM
  #6912
reggie l.'s Avatar
i also run the +2's all around i like em alot
reggie l. is offline
Old 05-02-2010 | 08:58 PM
  #6913
Thanks guys, but I never had any problems with throttle ive only replaced it once only because I put my seconed BLS 352 servo in for stearing. Is it possible that my stearing servo is also rubbing the mud guard? Thanks so much guys im going to look into the spacers.
Old 05-02-2010 | 09:38 PM
  #6914
steve307b's Avatar
I ran the short steering ackerman this past weekend on a track that had quite a few tight corners and the truck turned much better than with the long. I used to have to do a lot of brake checking to get around tight turns, but not anymore, so if anyone wants there truck to turn better on off power and hasnt tried this I would give it a try. To me it was like night and day. And the on power steering for me was still good, and the rear end still stayed planted on straits.
steve307b is offline
Old 05-02-2010 | 11:15 PM
  #6915
dnebout's Avatar
Yeah Steve. I was pretty happy with it to. By the way figured out my motor today. The weather changed so drastically since I last drove the truck at NorCal that I needed to lean out the bottom a bit and the top a whole bunch. Did you have to re-tune your motor?
dnebout is offline
