8T 2.0
#6841
is that with the split mount, or the stock diff mount? i have had the coller set screw hit my splash guard. none of the set screws, on the collers are hitting anywhere.
#6842
I think you might be having an issue because of the 1.0 brake discs. The 2.0 brakes are much thicker than the 1.0 discs. The 2.0 updated discs are even thicker than the original 2.0 discs, and the split mount was designed to use the updated black discs. Grab a set of the black discs. They are a must have anyway in my mind. 100% better than all of the old discs, especially the 1.0 ones.
#6843
Well you did something wrong. I'm not sure what, but you definitely did something wrong. Like Frank said, check your brake cams. If you put them in wrong they won't activate the brakes.
thats what im thinking that i need, to get the 2.0 brake disc that might be the problem. cause if i use the, stock diff mount the brakes work fine.
i just have to use the stock diff mount this weekend.
i only have enough to race this weekend, so i have to get the 2.0 brake disc later on.
#6846
your right man that has to be it. the nut that goes, on the split brake mount can only go to, the last thread on it will strip.
#6849
The short links will give you a bit more off power steering. They will allow the truck to rotate more at low speeds. You will lose a bit of on power steering. I like the short link setup personally. I say give it a shot! If you still have your stock turnbuckles(since you are running titanium ones), throw the stock front ones on the rear and try it out.
#6850
Split mount the collar that pass right underneath the top plate it all depends on far your adjustment point are at thou.
#6853
A blank setup sheet dot in extra holes add setup and post for the V2.
#6855
Here ya go. Just make sure you use the correct hole on the V2 tower its not the correct picture on the setup sheet.
http://www.losi.com/ProdInfo/Files/L...akeV2Tower.pdf
hey guys thanks for the info.
