8T 2.0
#5476
If you are in a main and carry on racing then the inner bearing dies soon after a spits the whole wheel and axle out and your left on the lower arm
time to quit
I was fitting bearings before any main, and still had failures the next weekend of qualifying!
Got some modded plastic hubs 3 months + ago and still on same set of 16mm bearings
Suprised losi haven't released an option rear hub to 'cover up' the error
#5477
With the factory hubs, 1st the outer bearing fails, so you get the wobbles....
time to quit
time to quit
#5478
We had a guy here in the UK get a load re machined.
I've heard 'j-dubs' named mentioned, I guess in the US?
Kingheadz do alloy hubs (possibly larger bearings)?
I also had the fronts fail on me last time out, but the bearings were the originals (6months old!).
#5479
Tried Casey's setup, I don't think it's for me, but I didn't get a good chance to try it out.....
I had my rear right drive shaft pop out of the output cup. The driveshaft end had always been very close to the outside of the cup (on the rear, front is well engaged). It didn't make sense to be the mod as I was still running the same camber. Put the car on the track & it happened again. Found under full arm lift (compressed shock) the pin, when at the bottom of the rotation was basically out. Change back to my original setup & it happened again. The left side JUST stays in, but right.... the diff is correctly shimmed. Now the slot openings are slightly damaged so it comes out fairly easily. Ending up finishing the day with 19mm (that's 3/4" for you guys using the outdated measuring system...
) of fuel tube on the shock shaft to control the maximum movement.
Is this a know problem, or is it just me? Another guy at our track, has had the same problem with the front, but not rear. My front shafts are quite well engaged & couldn't pop out.
Any advise would be appreciated.
Pete.
) of fuel tube on the shock shaft to control the maximum movement.Is this a know problem, or is it just me? Another guy at our track, has had the same problem with the front, but not rear. My front shafts are quite well engaged & couldn't pop out.
Pete.
#5480
If you lost all the ball's the cage wouldn't be there and the inner and outer rings have Nothing holding them together...therefor causing a DNF...i dont see why you think it cant happen.
#5481
#5482
Hi guys,
i just wanted to know your opinion about something, i never raced truggies, and this season, we are starting Truggy races here in Kuwait. since its the first year, not many people will race them. i would love to do so but dont want to spend alot of money, i came a cross an 8ight T 1.0 on ebay that looks great. now, how different are the 1.0 from the 2.0?? is it worth it to get the 1.0?? and if so, what do you recommend to change?? can we use the 2.0 body's on the 1.0??
cheers
Ali
cheers
Ali
#5484
Randystang i have been running the Extreme shock towers for about a year now and i have not had any probs with them and they have made it thought a hand full of hard crashes. I will tell you this i would buy them again in a heart beat.
#5485
Hi guys,
cheers
Ali
cheers
Ali
#5490
+1 on hudy but it does help if you take the lower mount screw out 1st and then rotate the shock towards the front of the truck to make more room. Its a tight fit. I think I am using a proline driver right now t works well too al song as you remove the lower screw 1st.
