8T 2.0
#4381
Just got a Losi 8T 2.0. thing is sweet, i am so excited to run it. The guy i bought it from took extremely good care of it. 2 questions, where is the cheapest losi or jconcepts body i can buy and where can i get a pair of those rear arm shields for cheap? Thanks !!!
#4382
No one makes the rear guards for the 2.0 T yet...so you have to make your own....Parma sells 12x12 sheet's of lexan in 2 different thicknesses that works good for that...or if you have an old body or the cut out's you might be able to rig up some....as for the body...any online retailer will have them at varying prices...check around for yourself....A-main Carolina's Tilted....its your choice.
#4383
Bobby I run the losi quickchange mount and use an ofna truggy start and it works great. I see you are in alabama, where exactly I live just outside of birmingham
Where do you usually race
Jason
Jason
#4384
I use a diamond hand file....but a dremel works just be careful to not let the bit or drum get out of hand....and for when to do it...when the shoes have a melted lip building up...you want to 45degree those edges i also do the trailing edge of the shoes as that get's build up there as well.
#4385
#4386
#4387
my JC 2.0E body is cracking around the RIDICULOUSLY hard to cut out vents....Not impressed to say the least.
Luckily this is a practice body and a i havent settled on a paint scheme.
#4388
Is their any particular areas which are weak just bought two new wraps form fastlane JC T 2.0 thinking I can lay down some Kyosho repair lexan in the areas that might have weak points.
#4390
#4391
i dont run the T body..only the buggy and E buggy body...one buddy who is running the JC 2.0 T body has no sign of cracks yet....but its only been race's a handful of time's...so we'll see how that pans out....i personally like the losi body better.
#4392
BN shoes require a little forced abuse on them to "mate" them to the bell.....on a brand new set-up before you start reving the peanuts out of it......drop it on the ground...Hold it in place and rev it for a couple seconds....DONT let the tires move.....your basically looking to force slip the shoes to break them in....dont go overkill and do it over and over....once is enough and your set-up will thank you with a little longer life.....with composite's be careful...even a few seconds of 100% slip can damage them...so be quick about it on a comp/alum set-up...as glazing over the composite shoes is the last thing you want to happen.
#4393
thank you
#4395
had a jc pun. body crack the first race, got worse after that. jc seen i posted about it on here and sent me 2 brand new bodies. hopefully the new one wont crack
