8T 2.0
Old 05-13-2009 | 05:18 PM
  #2506
Frank L's Avatar
Originally Posted by Stanton
Sorry Frank-I think were saying the same thing. Saw your post after I did mine. My bad!
No prob man that just means we agree.
Glad to see I'm not the only one doing it this way. It is kinda a hit and miss kinda thing.
Frank L is offline
Old 05-13-2009 | 05:25 PM
  #2507
jzemaxx's Avatar
Originally Posted by JAMMINKRAZY
Solution would be to put the 2mm hexes back on I found that on all but the AKA wheels, the webbing rubs the very back tip of the front arm where the hinge pin/screw is. I run the 2mm hubs and no rubbing for me! I also noticed a tick more steering with the 2mm hubs also.
RC8T stock wheels work perfect. Try them....no spacers needed and no rubbing.
jzemaxx is offline
Old 05-13-2009 | 05:27 PM
  #2508
Frank L's Avatar
Ever cracked any. I have been having a chronic AKA wheel cracking problem with my 2.0
Frank L is offline
Old 05-13-2009 | 05:29 PM
  #2509
jzemaxx's Avatar
None yet.....been running them on my RC8T-E with 6S, so its a little heavier then even the nitro setup. Truck runs great with them and even had some hard smacks into the ground over some big triples and nothing so far.
jzemaxx is offline
Old 05-13-2009 | 05:46 PM
  #2510
JAMMINKRAZY's Avatar
There will be no AE parts on my truck, thank you. LOL JK. But in all seriousness I am having luck with the 2mm hubs and that way I can run any wheels I like.
JAMMINKRAZY is offline
Old 05-13-2009 | 06:28 PM
  #2511
slumlord's Avatar
Originally Posted by losi_racer
and im going to order the camber and wing bolts but does anyone have a part number?
I ordered the Tony's Screws kit for the 2.0 and it's awesome. Comes with everything you need and the longer camber/wing bolts you need.
Also with the wing I've noticed that it works real well if you drill through the back of the hole where the bolt goes so that your lock nut gets fully threaded onto the bolt.
slumlord is offline
Old 05-13-2009 | 06:41 PM
  #2512
l3asher's Avatar
I have been on the phone with Mark @ AKA. They have a stonger rim coming out (something to do with the plastic they are made with). I cracked 4 rims and he sent me new rims and tires (siince there were cityblocks). I had to send the cracked rims/tires back to them. No questions asked for the new set. The new rims are in and should be shipping. I will have to pull up my email telling you how to tell the differance between the old and new. If you have a set of the old rims, boil them for 3 minutes before you mount them and you should be fine.
l3asher is offline
Old 05-14-2009 | 12:06 AM
  #2513
SqueegUK's Avatar
Two things why I changed back to stock:
1. I replaced the stock plastic spindles with the ali ones. Tried to put the hubs back on, I use Xray +2's due to less play, and they were so tight, I could hardly turn the drive shafts. Put the originals back in and they were a lot looser?????
2. I believe it has been mentioned that with the standard hexes, the car will have more traction. I have yet to verify this as I didn't have time last Sunday to try the two on the track back to back.
Is anybody else using the Xray hexes to help take some of the slop out?
SqueegUK is offline
Old 05-14-2009 | 01:15 AM
  #2514
I just use shims behind the hexs to keep the slop out. I only shimmed 2 of the hexs because the rest were fine. I use the +2 hubs and I have no problems with traction.
LosiMadMan is offline
Old 05-14-2009 | 01:41 AM
  #2515
Hey guys
Well I am going to be buying a Losi 2.0 Truggy tomorrow and am wondering what I need to do such as shimming the diffs (also what is this) and other things I have to do before I get on the track... I am going to be using Proline LPR mounted Crimefighters M2 tires...
RUF-VK is offline
Old 05-14-2009 | 03:56 AM
  #2516
T0MM0's Avatar
Originally Posted by RUF-VK
Hey guys
I ran mine for 5 tanks .. before racing .. things that came off were the plastic bits on the end of the shock shafts , they seemed to be just stripped as if they was done up too tight in the factory and a plastic steering servo horn but i changed that for alloy servo arm .. then i ran it for 10 mins of practice, 28 mins of heats and 20 min final with no issues .. although i did bend a rear shock shaft but that was due to a bad landing.
Striipping down as we speak.
T0MM0 is offline
Old 05-14-2009 | 04:33 AM
  #2517
Any other issues guys?
Also could you guys supply some links so i buy these extras?
Also what is this diff shimming you guys are talking about?
RUF-VK is offline
Old 05-14-2009 | 05:12 AM
  #2518
You can shim the diff ring and pinion gears now in the 8ight line of buggy/truggys by placing shimms on one end of the diff or the other.
Call horizon if your shock ends are stripped.
Old 05-14-2009 | 05:54 AM
  #2519
slumlord's Avatar
Replace your camber link and shock mount screws. They're too short and will fall out!
slumlord is offline
Old 05-14-2009 | 06:17 AM
  #2520
l3asher's Avatar
Originally Posted by slumlord
Replace your camber link withshock mount screws. They're too short and will fall out!
I think you meant this.
l3asher is offline
