New Caster Racing Nitro Buggy Just Announced!
#512
2 degrees negative Camber front and rear wheels
5-5-2 diff fluid
Rear lower hinge pins in UP position
Front upper hinge pins in UP position
Front shocks in inner hole on lower arm and outer hole on tower
Rear shocks in outer hole in lower arm and 2nd to outer hole on tower
Rear upper arm in middle center hole on tower and outer hole on hub
If you are running larger tracks the 44T center spur will be ok. If you are runner shorter tracks you need to get the 46T spur that came out with the 1.5R, which will give you alot more bottom end.
Do you have a pic of it? Just want to see what steering turnbuckles are on it. If they are stock 1R ones then you should upgrade to the 1.5r ones. The old 1R ones were known to break a little to easily. 1.5R ones will not break.
Do you have a 3 degree toe plate on it? If you do and its fine your ok. If you find it pushy at all try the 2.5 toe plate.
You should love that buggy. It was known for being extremely easy to drive and drive fast.
#522
1 degree toe out front wheels
5-5-2 diff fluid
5-5-2 diff fluid
#523
yes there is. The new style upper arms are not as wide and are moved more forward toward the tower. They take the caster out of the front knuckles and make them stand more straight up supposedly making the steering alot more aggressive. The old style arms make the knuckles laid back alot. I have these new arms on my RTR ZX1.5R with the crappy RTR ackerman plate and the thing turns which I did not expect. The same ackerman plate with the old style upper arms and the buggy pushes like crazy.
#524
#525
Another really good motor to get is the Werks B5 which I can get for you too. http://holeshothobbies.com/index.php...roducts_id=543 a ton of people are running this motor where I am at and its an awesome motor.
You will not be disappointed with the OS.21 though.
