Team Associated SC8 Setup and Tips
#316
My first time out on the track with the SC8 I was in the second qualifier and the wheel comes flying off. The whole center of the wheel was broken out and ended the day.
Team Associated did replace it but this is what they said.
"We found this to be from crash damage and normally it would not be replaced. We our sending a replacement wheel.
They will not be replaced in the future, based on crash damage."
Like everyone else I flip and rolled it a few times but nothing extreme not like I was trying to clear the triple. Even if I was there should still be no issue.
After inspecting the wheel you can tell that the plastic is very thin, much thinner than that of a Pro-Line or other race wheel.
I personally don't think the wheels can support the weight of the truck.
With that being said I like this truck and really hope this class takes off and because no one else has posted this issue maybe it was just a bad set of wheels.
#317
OK, first of all I'm the noobiest of the noobs to RC, but when I saw the SC8 I had to have one. Anyway, I've been reading all I can about tuning, and watching youtube vids. I've been having a heII of a time getting it started, but I finally did today, and got it to run a little. But I think I need to increase my idle a bit but I can't get access to that idle screw. How do you guys do it? It seems like I either have to remove the pipe or pull the engine. Or is there an L shaped screwdriver? Help, please!!!
or a long skinny screw driver and pull the plastic side piece down. have done it both ways, the first is the better.
#318
Thanks GNS - worked like a charm. Although I'm still having troubles starting it. I'm taking it to the hobby shop tomorrow.
#319
Attachment 440331 Attachment 440332
I think ya must have gotten a bad one because I have ran mine with no problems
#320
Are there any pull starts that will work on the SC8 engine? I've pretty much stripped my pro-start shaft. Hopefully it's not stripped at the entry to the engine too. I'm trying to get in touch with Associated, but in the mean time I might get a start box or pull start, if there is a compatible one. Their Pro-Start system is ridiculous.
#322
Suspended
If the shaft stripped the engine is probably fine, the shaft is softer than the input nut on the engine.
Not to sound like an AE fan boy or something but I like the Prostart....enough that I don't bother bringing my starter box with me, it's lighter and easier to use...
#323
I'm a noob on nitro engines. I know that a nitro engine's life is very short. Dependent how you abuse it. Lets say, after 8gal. If your engine has no compression anymore and fails many times. Can you then just replace these =>
After you have installed these, is your engine then as good as new and have to be breaked in again? Or do you have to replace the whole (expensive)engine? I can't also find these parts for the .28engine!
#324
When the engine looses compression, you can replace the piston & sleeve (what's in the photo). You have to break it in again. It's a good idea to replace the connecting rod as well.
You can also have the sleeve "re-pinched". This is the process of putting the sleeve into a steel clamping ring and essentially squishing the sleeve to get it down to a smaller diameter to get the compression back. Guys will take this route sometimes before buying a new P/S because it usually costs less than half what it does for a new P/S. But, re-pinching the sleeve is only a temporary solution allowing you to get maybe 2-3 more gallons through it before it looses compression again.
#326
The pull start for the Pro28, or 4.6 from associated will work just fine....I don't have the part # handy but if you cannot located it on your own I can find it for you. It's the same pull start for the MGT, it comes in a entire kit for like $50...
Are you sure about the pull start? I asked the cust service guy about that also and he said he wasn't aware of any pull starts that would work.
#327
I also called AE today and talked to "Billy." He stated that the stock motor was built for an RTR and that there really is no parts for it. Now if I am correct this is a thunder tiger motor. I got ahold of them, in which I was directed to ACE Hobbies. Talked to a gentlemen there who in turn told me to contact Thunder tiger. See what is going on here......Well after a few emails back and forth with thunder, I called AE again and was assured there was nothing for the stock motor.
Though I could have sworn I saw a post about someone utilizing a back plate from another vehicle. If they would only post up again.
#328
Suspended
As for a blank backplate, I don't know of one....but I am sure the pull start is possible.
#329
Suspended
Part # for you guys wanting a pull start...
AE Pull Start System, 4.6
ASC25366
Here is a link to it on horizonhobby.com
http://www.horizonhobby.com/Products...rodID=ASC25366
ASC25366
