8IGHT 2.0!
#5446
I see the 8 eu isn't going to be sold in the us does anybody know if we are going to buy parts from it? I think all I will be using is the shock caps but possiably might experiment with the shock towers. I'm so curious to see how different the setups are going to be compared to the us version if you will.
#5448
#5449
Cary,
Part number for the complete set is LOSA1728 they are only on the Horizon site right now as far as I know.
They also have them seperate.
LOSA1729 Inclined Spindles
LOSA1733 Spindle Carrier 12* Caster w/ Incline
The 10* Caster Spindles that have the new Incline for the new Spindles were not out last I checked. Part # LOSA1734
They also have the Hinge Pin Braces that are Black Ano that will be released too.
LOSA1758 Rear Adj.
LOSA1787 Front Adj.
The Shock caps are still not out on the Horizon sight till May I think.
LOSA5422 Shock Cap Vented
LOSA5431 Foam Compensator
LOSA1758 Rear Adj.
LOSA1787 Front Adj.
#5450
Can someone explain this?
#5451
Sorry for the delayed response but the part # is LOSA1728. Here is a link
http://www.horizonhobby.com/Products...rodID=LOSA1728
All I know is at silver state Truhe told me they gave him one set for his buggy and truggy and he liked them so he was running them. Mike has always been right on the $$$ every time. I am going to test them on Sat.
#5455
frank doesnt mike run the 10 degree carriers ? that what he had on his buggy at the psycho nitro blast ....there is a 5 degree incline on the angle the king pins go into the carriers ...mike said it helps the buggy in mid corner to exit ...because of the new geometry ....
#5456
Ive Tried multiple different brands of springs and even the cheapo ball point spring's and could never get them to work the way i would like to, So good luck in getting them to work for ya. I feel they are not required.
#5457
Team EAM
EA
#5458
If it works like it does in TC it should give you more caster and camber gain when the wheels are turned. We had some prototype stuff in TC a couple years ago that some guys still run. The kingpin hole was drilled for 4 degrees of caster in the steering block. Works awesome mid corner.
EA
EA
#5459
Team EAM
yup he said it just is so much better right there that is just sick ...hey on a lighter note ...lets do this rebel classic me and burton headed up today should be there around 2 pm ...see ya soon looking forward to some good racing ...and hey we can just quiz drake on it cause you know he will have em on there
Yep Ive got to work till lunch or so tomorrow so it will be after that when I get up there. Should be a great race though. They have put a lot of money and work into the track the past few weeks.
EA
#5460
Cary,
