Inferno MP9 thread >
Inferno MP9 thread
Like Tree1Likes
Inferno MP9 thread
    Hide Wikipost
Old 10-10-2016, 02:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Inferno MP9 thread
Last edit by: tobamiester
Another TKI thread, more TKI4 Specific http://www.rctech.net/forum/nitro-of...buggy-kit.html
TKI4 Replacement Parts (Good for upgrading from TKI3) http://www.kyoshoamerica.com/Replace...ts_c_1505.html
TKI4 Optional Parts http://www.kyoshoamerica.com/Option-Parts_c_1506.html
Some notes on the new Towers/Long shocks here
Picked up a TKI3 and want to upgrade to TKI4 ? Here are all the updated parts:
Shocks
IF347-155 1.5X5 Pistons
IF471-01 Front Shock Body
IF470-01 Rear Shock Body
IF470-03BK Shock Adjust Dial
IFW154 Boots
IF346-05C Shock End Set
Wing
IF491BK Wing
IFW460B Wing Mount/Stay
Rear End
IFH006W Wheel
IF490 HUB
IF490-01 Hub Insert
IF492 Shock Pin
IF423HB Rear Arm
IF287 Hard Upper Rod Rear
Front End
IF489 Steering Rod Set
IF488 Knuckles
IF487H Front Arm
IFW458 Hard Lower Pin
IFW425 93MM CVD
IF286 Hard Upper Rod
IF486 Lower Susp Holder
IFW459 Servo Saver (Hard)
IF446B Ackerman Arm
IF426-64.5 Susp Shaft
Other
IF469B Filter
97035LW-13 Clutch Bell
IF453B Body Mount
IFW107GM Hexes
W300910 Washer
IF443B Center Diff Plate
IF444C Tank
IF479B Radio Box
96772 13x16x0.15mm Shim
IF481B Fuel Tank Stay
IFW336GM Wheelnut
IFB008 TKI4 Body
IFD403W TKI4 Decal
Print Wikipost
Old 08-04-2011, 07:04 AM
  #6676
CoryD's Avatar
Originally Posted by aaron125
Man that is awesome, how did you find it?
Was on a friends facebook site. No CLUE how he found it.
I have said most of thoes things
Later,
CoryD is offline
Old 08-05-2011, 01:22 AM
  #6677
Default engine
I'm curious to know just how many people had to trim their engine mount in order to clear the rear driveshaft. Did you need to trim cody's in order to fit that CRF PK?
nicker619 is offline
Old 08-05-2011, 02:37 AM
  #6678
needs to be done to most engines.
RAlmeida is offline
Old 08-05-2011, 02:42 AM
  #6679
808gx7r's Avatar
fits alphas gos etc fit fine. some guys here has ran speeds, werks, as far as im aware they didnt have to trim anything.
808gx7r is offline
Old 08-05-2011, 06:23 AM
  #6680
revrace's Avatar
I had to trim for the SPEED but not for my newly installed Orion.
revrace is offline
Old 08-05-2011, 07:00 AM
  #6681
CoryD's Avatar
I had to mod up my novarossi's as well.
CoryD is offline
Old 08-05-2011, 07:37 AM
  #6682
Trader Rating: 156 (99%+)
+1 OS cases need a bit of shaving on the block tab, but the Orions just slide right in
skoalisbad4me is offline
Old 08-05-2011, 11:05 AM
  #6683
I have both engines. The Team Orion CRF 5 port and I mocked it up and it appears its going to hit. I also have a OS speed xz-b and it looks like it may ever so slightly clear but in the event of chassis flex it would likely rub.. I personally hate the idea of shaving my engines but it appears I may not have a choice..
What oriion motor do you guys speak of?
Old 08-05-2011, 11:56 AM
  #6684
houston's Avatar
Trader Rating: 96 (100%+)
Its really not a big deal , you guys really should trim pretty much all engines as the rubbing occurs mostly during chassis flex
houston is offline
Old 08-05-2011, 04:37 PM
  #6685
Trader Rating: 47 (100%+)
Guys is the MP9 SE still competitive
transplantlife is offline
Old 08-05-2011, 04:45 PM
  #6686
808gx7r's Avatar
any mp9 platform is more then capable...theres no real actual "big" differance. except the price. lol
808gx7r is offline
Old 08-05-2011, 04:46 PM
  #6687
Trader Rating: 16 (100%+)
yes for MP9
Re: engine fit I initially thought my Speed VZ-B was fine but many others said they had to shave off some metal to make theirs fit. Couldn't understand how mine could be any different from anyone else's & turns out that the blue 777 blocks I used are slightly taller than the brown MP9 blocks, enough to lift the engine out of the way of the rear centre driveshaft. I put on the MP9 blocks a month or so ago & had to dremel a bit of material to allow the engine to fit without any contact.
aaron125 is offline
Old 08-05-2011, 08:34 PM
  #6688
pitpop's Avatar
Hi Nicker. I do use the dremel and shave the flange on the drive shaft side of the engine. Even though the engine might go in without it, I like to do this for clearance. I just don't like the idea if the chassis flexes it might rub, and also the heat transfer from the engine to driveshaft and gearbox. I like the extra clearance..
pitpop is offline
Old 08-06-2011, 12:40 PM
  #6689
rcmadnes's Avatar
Anyone know what body David Ronnefalk used at the Euros on his MP9?
http://gallery.neobuggy.net/2011Race...6_qxx2hcq-O-LB
rcmadnes is offline
Old 08-06-2011, 12:56 PM
  #6690
ecpete's Avatar
Trader Rating: 39 (100%+)
Bitty Design makes it.
ecpete is offline
