Inferno MP9 thread
#2763
#2766
just another note bschorr what about a track conditions section
#2767
I don't think there's room on the front for stuff like that ..would start to make the setup sheet cluttered..all mine have notes on track conditions and my personal thoughts/observations scrawled on the back..I note things like how I found it in entry/mid/exit on corners etc..straightline stability bump handling in the rough and so on..then I change settings ONE AT A TIME and note handling changes ..whether +ve or -ve...If you start with a top racers standard settings as a baseline and go from there it's quicker..these buggies have so many adjustments now I lose track otherwise...
#2768
good point dude does anyone know if base setup has ben updated i heard pitpop talking about running shorter upper arm and 2.5toe
#2769
Guys what is the difference when changing the ackerman angle on the steering plate? i had it to hole c and i changed to b. Do i have to redo the toes now?
#2770
Hi Guys,
Where's the best place to get the following parts from, who actually have stock.
IF346-04L
IFW410
IFW406
IFW405-138
It's just no ones seems to support it very well in the UK & dont even have stock of common parts either.
Starting to become nightmare having to order parts then waiting 1week half for bits.
IF346-04L
IFW410
IFW406
IFW405-138
#2771
#2772
Hi Guys,
IF346-04L
IFW410
IFW406
IFW405-138
IF346-04L
IFW410
IFW406
IFW405-138
#2773
#2774
and yes, recheck you toe setting after words because the distance changes, it wont take 5 minutes to do so.
hope this helps
cheers
Ali
#2775
what do you think i need to stock up on for the upcoming jconcepts race for my mp9? right now, i have front/rear arms, F/r hubs, gearbox, clutch shoes and clutch springs. what other parts should i get? im not on a budget so list away!!! i just switched from a losi to a mp9 so i dont have many parts at all!
