TQ Racing SX8
Old 11-09-2009, 01:51 AM
  #2371
Hi All,
Some questions to ask:
Had original caster knuckles, stripped these, purchased new pair of CNC knuckles stripped these on the weekend, anyone else having issues, any tips would be greatly appreciated, going back to caster knuckles can’t afford $50 USD for a pair of knuckles and only lasting ¾ of days racing.
Thanks for all your help
Jesussaves is offline
Old 11-09-2009, 01:59 AM
  #2372
jfc_tech's Avatar
Originally Posted by Jesussaves
Hi All,
Caster??
jfc_tech is offline
Old 11-09-2009, 02:40 AM
  #2373
Originally Posted by jfc_tech
Caster??
Part Number BB2043, link: http://stores.ebay.com/RCPROCENTERNE...=steering+arms
Old 11-09-2009, 03:14 AM
  #2374
Hi All,
I would check your screws or just get some of TONY"S SCREWS to replace those.
jlog is offline
Old 11-09-2009, 08:42 AM
  #2375
Disel760's Avatar
Caster??
What are you a spell checker or a word checker. Poor guy just asked a question.
Disel760 is offline
Old 11-09-2009, 10:25 AM
  #2376
Chill_Will's Avatar
Trader Rating: 33 (100%+)
Hi All,
Congrats, you have found the weakest link.
Thats the only thing on the buggy I have had problems with. The CNC last longer but the Cast ones don't like it went you snag a pipe.
Chill_Will is offline
Old 11-09-2009, 10:28 AM
  #2377
Chill_Will's Avatar
Caster??
He was talking about the Cast Aluminum ones. We know what he means.
Old 11-09-2009, 03:55 PM
  #2378
kamlooper's Avatar
Hi All,
What do you mean by stripped? The threads where the steering rod bolts to? Just use a longer bolt and nut. If you mean the kingpins make sure your threads are clean and dont overtighten.
Ive only broken 1 knuckle on a cast one, no problems with cnc ones.
kamlooper is offline
Old 11-11-2009, 04:58 PM
  #2379
RoyJ's Avatar
Default Full-Proof Knuckle-Drag Prevention
1. I've learned to first clean new knuckle bolt-threads with brake cleaner, since they usually have a little oil on them. Remember how shiny black the hardware was in the kit? Then I apply red threadlock evenly on the first 4 threads. Yes red, but not too much.
2. When reusing bolts in rebuilds, I'll first screw them into a 4mm die to clean the threads of hardened red residue, before applying fresh threadlock. A hobby knife works well if you're without the die tool.
3. Tighten with a T-handled allen wrench, for max hand-torque.
4. Unfortunately the threaded inserts on the cast-aluminum/stock knuckles allows enough play in the kingpin area that the bolts can work loose, and gradually strip, even with redlock. Therefore I glue the threaded inserts to the knuckles with either medium or thick CA before assembly. No more wiggling insert.
Any mfr's cast knuckles can break in a crash. So because accidents do happen, I run the cnc types on my primary race buggy. Just allow the threadlock to set-up overnight. Then check the knuckle bolts after your first few tanks on race day. Now you'll never be caught dragging a knuckle in the main.
Hope that helps.
RoyJ is offline
Old 11-12-2009, 04:22 PM
  #2380
Disel760's Avatar
Default Roy Hit the spot I do the same
Hope that helps.
Disel760 is offline
Old 11-12-2009, 08:05 PM
  #2381
kamlooper's Avatar
Anyone need a roller for spare parts pm me. Also lots of nip parts available.
Old 11-16-2009, 02:34 PM
  #2382
TQ NOOB's Avatar
Anyone know if Luther is still Kicking around?
TQ NOOB is offline
Old 11-17-2009, 11:01 AM
  #2383
Chill_Will's Avatar
He's around here somewhere.
Old 11-17-2009, 02:44 PM
  #2384
hey guys i got 3 roller sx8 for sale and ton of parts pm me....
doc6 is offline
Old 11-18-2009, 09:16 AM
  #2385
Local racer's Avatar
Default I am here
Whats up guys I am sorry but I am bouncing back and forth at the moment,allorders have shipped and tqnoob please give me a call.
Local racer is offline
