Like Tree23Likes
Kyosho ST-RR
    Hide Wikipost
Old 10-19-2017, 10:14 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho ST-RR
Last edit by: tobamiester
Current running upgrades/Mods people are doing to this truck late 2016/early 2017.
-Chassis Options
m2c2850 KYOSHO STRR EVO WEIGHT FOWARD TRUGGY
-Engine Mount Option
IFW102 - Blue narrower Mount. Allows you to put Lock Nuts on top of screws that hold the Mount plates in.
Agama motor mount AGM6206
-For MP9 Knuckle conversion
Kyosho IF419 MP9 Knuckles
Kyosho IFW436 16degree Hub Carrier
Kyosho IF420 Knuckle Arm Collar (slightly thinner than STRR one)
Kyosho IF467 Long King Pin
-Strengthening upgrades
King Headz KP-360-BLK Front Torque Arm
King Headz KP-372RR-BLK Rear Torque Arm (extended chassis)
King Headz KP-300LB-BLK Lower Front Holder ‘B’
King Headz KP-300UL-BLK Front Upper Holder ‘L’
King Headz KP-329 Rear Brace Mount
IS157 Hardened Diff Case from Psycho Kruiser
IGW002GM Alum Rear Hubs
HB Outdrives #67197
-Replacing C-Clip Hinge Pins on Inner Susp Holder
HPI 109848 Hing Pins
Racers Edge/KFactory RCEK8034 Pins (Very hard to find)
or
Replace complete A/B/C/D Blocks with:
*M2C m2c2510 KYOSHO ST-RR/ EVO REAR TOE BLOCK
*M2C m2c2520 KYOSHO STRR EVO TRUGGY FRONT LOWER ANTIDIVER KIT
-Servo Saver Mod
IFW450 MP9 SS Alum Upper Arm
IF417 MP9 SS Lower Assembly
(See http://www.rctech.net/forum/showpost...postcount=4112 for full pics and description).
-Performance Updates
IFW327BL Blue Narrow Hexes (typically run on front).
-Bodies Options
RC8T Bulldog Body (discontinued late 2016).
Print Wikipost
Old 11-13-2016, 05:31 PM
  #4216
carpet Carlos's Avatar
Originally Posted by big lou
Yes! Roscoe and a few others have done it.
Yeah I wouldn't do that. Where is the benefit? Corner speed ? Because right now my truck corners awesome
carpet Carlos is offline
Old 11-13-2016, 06:19 PM
  #4217
Trader Rating: 28 (100%+)
Gotcha! Just curious why I've seen others doing it.
big lou is offline
Old 11-16-2016, 06:59 PM
  #4218
Do hb d8t front arms fit this truck?
carpetburner is offline
Old 11-16-2016, 07:57 PM
  #4219
HaulinBass's Avatar
Trader Rating: 16 (100%+)
no
HaulinBass is offline
Old 11-30-2016, 10:06 PM
  #4220
JD@808's Avatar
Default Replacement body
Does anyone know if there are different body options?
JD@808 is offline
Old 12-01-2016, 05:57 AM
  #4221
tobamiester's Avatar
Trader Rating: 360 (100%+)
I've seen folks running the RC8T PL Bulldog body.
tobamiester is offline
Old 12-01-2016, 07:28 AM
  #4222
ROSCOE's Avatar
Trader Rating: 130 (100%+)
Body option
http://www.rctech.net/forum/14392692-post3883.html
ROSCOE is offline
Old 12-05-2016, 11:20 PM
  #4223
KyoshoRed's Avatar
Questions??
Originally Posted by pntmachine
It shows it in the exploded view. There should be 4 black threaded hinge pins with slotted head and 4 3mm aluminum nylon nuts. Its the same pins front and rear.
Maybe I'm just missing it but where is the EVO 2 exploded view? I have the EVO 1 exploded view but Im looking for the EVO 2 one with the few updated parts on it. Can someone please link it or show me the way to it so I can print out a copy? I like to have all current exploded views printed out and on the wall of my rc trailer in case i need to buy a part at a track then I dont have to get online and look up part #....thanks
KyoshoRed is offline
Old 12-06-2016, 08:35 AM
  #4224
Motorman007's Avatar
Trader Rating: 89 (100%+)
http://www.kyosho.com/eng/support/in...uck_index.html
http://www.kyosho.com/jpn/support/in...RR_Evo2_IM.pdf
Page 42
Motorman007 is offline
Old 12-09-2016, 10:48 PM
  #4225
Default Clutch is fubar
Second race in a row, using stock clutch assy with hard shoes, works fine in qualifiers, but seizes during the A Main. Clutch recommendations? Desert area, hybrid track.
Twizter68 is offline
Old 12-10-2016, 12:10 PM
  #4226
Trader Rating: 21 (100%+)
When u say seizing explain exactly what the shoes are doing?
rcmoe is offline
Old 12-10-2016, 12:12 PM
  #4227
Winner's Circle's Avatar
I had this happen to me once when I didn't leave enough end play on the clutch bell. On longer runs the clutch bell would heat up and the end play would disappear and it would lock up.
Lee
Winner's Circle is offline
Old 12-11-2016, 09:11 AM
  #4228
The bell will not freewheel at idle or off-throttle. The shoes don't appear to be binding, I rebuilt using new shoes, springs, and bearings. It worked fine through 3 Qualifiers, but at the A main, it seized up and wouldn't break loose...to the point we had to use a screwdriver to get the bell off.
Old 12-11-2016, 12:21 PM
  #4229
Trader Rating: 24 (100%+)
Is it the bearings siezing up or the clutch shoes getting stuck to the clutch bell?
fenton06 is offline
Old 12-14-2016, 06:05 PM
  #4230
RCworks216's Avatar
Trader Rating: 26 (96%+)
http://www.kyoshoamerica.com/Inferno...y_p_23870.html
looks like the trucks back in stock. does this mean our local hobby shops can get them soon?
RCworks216 is offline
