Odonnell Buggy!!!
#1548
If you built the standard kit and not the team, the long shafts up front and the short ones in back, and this also means not using the cvd's, but the uni's instead.
#1549
What did you find out with the half shafts? As Agent brought up, make sure you're not using the set from the Team stuff. If you had to assemble them, you're using the wrong set.
If need be - post up some pics of the problem. If the problem still exists.
#1550
I have not touched anything in the team set. Only the Gen1 kit using the Gen1 manual
When I put the front universals in the rear, it looks good, however the rear in the front makes the front dog part come out at full compression.
so switching front to rear will not work,
the rear are not comming out per say, but it's really close to the edge, I would have though using longer half shafts like the front would have not only gave safety margin but also allow drivers to keep less spares.
Team kit however looks like they are all the same length? at least manual doesnt' specify different lengths.
#1553
You should be just fine once you set the car up, but let us know for sure.
Now set that car up with the Team parts already!
#1554
Overall I give this car a 9/10.
missing screws, and some screws that I thought should be 18 instead of 16 or 20 instead of 18, I like a little thread showing when the lock nut is tightened.
#1555
considering how well this car is built, i'm seriously considering letting go of the team kit.
Did the threads meet the nylon? If so, that's exactly what you want. More than a thread going thru the nylon will weaken it's hold. In fact, we should be replacing nylon locks after one use. ....I know what you mean though, most people want three or four threads showing once the screw is tight, but myself I like it to be right on the edge.
Not sure what to tell you about the missing screws except ... the guy that counts screws didn't work that day. ..and he had a cold. ...and he was fired. hehe.
Go wear in that buggy!! If you didn't ream the arms, or do a little fine sanding, you got about two gallons to put thru it before it REALLY starts to behave how it should.
Still though - I think you'd really like the Team setup. Smooth, yet aggressive.
#1556
Was going to send this body off to be painted. I then realized that I had all day Saturday to do nothing before Race DAY tomorrow.
So last night, I painted it and to the delight of my neighbors, this morning I trimmed and dremel'd it.
Following the 'Keep it Simple, Stupid' rule and also the 'Just use a spray can, man' thought of Eddie Van Halen, I ended up with the following;
Ready for decals! (wink wink, nudge nudge)
Now for a rather blurry look inside. Engine is a GRP 'Tuned' .21 mated to the stock flywheel/clutch and a GRP 2050 Mid-range pipe.
Servos are BLS451 for throttle/brake and BLS351 for steering.
#1557
Thinking about getting the zo1b. Was hoping to get some info from some people who own them. I curently own a rc8 any info would be great.
#1559
thanks good read that helps still not sure what to do luv me rc8 but not sure if I want the new one. keeping my options open.
#1560
Great idea, nice paint job. Yes, I do ran that Z01B too and really love it alot. So far the only problem I had was the steering knuckle but I've replace with the hyper 8.5 cnc knuckle and doesn't have that strip problem anymore no matter how hard you drive. I always love the Kyosho and found the OD car are very similar to the kyosho. From now on the OD car is my choice.
Mike T
