Like Tree1Likes
CEN Matrix TR
Old 04-11-2007, 07:03 PM
  #286
chucked's Avatar
Anyone know what other springs (for other kits) will fit the TR? I've heard that the mbx5t springs will fit - any others?
chucked is offline
Old 04-11-2007, 07:16 PM
  #287
t4usee's Avatar
I think the Jammin will fit also.
t4usee is offline
Old 04-11-2007, 11:02 PM
  #288
Atom357's Avatar
Trader Rating: 19 (100%+)
What would be a direct fit for the following items.
1 Fuel Tank (Larger capacity)
2 Motor Mound
And what do you guys think of the progresive springs, something easy on the ruff stuff, but dont bottom out on the big jumps.
Atom357 is offline
Old 04-12-2007, 05:14 AM
  #289
Trader Rating: 28 (100%+)
Originally Posted by Robert.Hull
headrushhobbies = online parts = shipping= DUH
except from his post, it looks like he would like to support his LHS, not an online shop, I could be wrong, but thats the impression I got from his post, Im sure the guy isn't stupid and knows he could get parts online if he wanted to, but some people like to help keep their local shops open, rather then help keep someone elses local shop open,
bobf24 is offline
Old 04-12-2007, 06:55 AM
  #290
chucked's Avatar
The big bore, or the regular ones?
chucked is offline
Old 04-12-2007, 02:31 PM
  #291
t4usee's Avatar
Would need to be the big bore type.
t4usee is offline
Old 04-13-2007, 04:30 AM
  #292
rregl0612's Avatar
Trader Rating: 33 (100%+)
Yup I was looking for local support although I am not against the click and ship theory ... but I will give him the opportunity to please me first.. hes looking into getting direct... and will also give horizon a call.....
Thanks for your Help Guys..
rregl0612 is offline
Old 04-13-2007, 04:48 AM
  #293
slakr's Avatar
Trader Rating: 36 (100%+)
Default CEN Martix TR Arena RTR and Matrix C1 ARR
I am seriously considering the CEN Martix TR Arena RTR and Matrix C1 ARR.
So far I really like what I have seen and read about TR Arena and I do not currently have a Truggy.
As for the C1; I do currently have an MBX5 Prospec buggy, but might switch just to keep it all in the family.
Anyway; my question pertains to the engine mounts, particularly on the C1 ARR.
Are they the same as the engine mounts on the C1 RTR? Or are they the same as on the C1 Pro?
The reason I ask this is that I like using a roto start.
So, I would assume an engine with a roto start backplate would mount right up on the C1 RTR and TR Arena RTR; since they both include a pull start engine.
However, with C1 ARR, I am not sure what the included motor mounts are like.
Also, is there a roto start backplate available for the CEN engine that is included with the TR Arena?
My LHS says there is; but I haven't been able to find it on the internet.
Thanks in advance for the help and for providing this is a very informative thread.
slakr is offline
Old 04-13-2007, 09:47 PM
  #294
Trader Rating: 16 (100%+)
Talking
Hey guys, been racing my Arena since it was released in Janurary. I got the cross pins and blue clutch shoes from Gene a while back. Haven't done much upgrades, but so far the truck is awesome. I've read what u guys have posted and they are pretty good ideas. I do have a question though, what's the benefit of switching to 17mm hubs beside having a more options for different wheels?
I sat down today and did the mod by grinding down the upper arm at a 45 degree angle, putting the nut at the bottom, using the outer hole on the ackerman and putting the pin in the lower hole on the tower. I also grind the part of the arm the caster block was touching I can see that I got more downtravel and more steering.
I got the RTR version and all i've changed was the rear toe block and the upper bell crank. This truggy is sweeet. All of the guys at my local track are now intrested in getting one. Here are some pics of the beast.....or beauty.........you decide!
Mystikal8885 is offline
Old 04-14-2007, 01:14 AM
  #295
im not positive cause of the way the pic is but.....make sure you run MTR tires
Robert.Hull is offline
Old 04-14-2007, 03:51 AM
  #296
I changed the pic Rob. This one looks much better I think.
Old 04-14-2007, 07:00 AM
  #297
slakr's Avatar
Originally Posted by Machine's R/C H
The RTR TR Arena imo is the best RTR you can get. But to be race worthy, he will need to get the CNC susp holders. Everything else is good or the same as on the FRE.
What exactly are the part numbers you recommend?
There are many...
Front Upper Suspension Plate - MXS28
Front Lower Suspension Plate - MXS29
Rear Suspension Mount (Front) - MXS30
Rear Suspension Plate T2S2 - MXS22
Rear Suspension Plate T2S3 - MXS23
Rear Suspension Plate T3S1 - MXS31
Rear Suspension Plate T3S2 - MXS032
Rear Suspension Plate T3S3 - MXS33
Thanks.
slakr is offline
Old 04-14-2007, 07:01 AM
  #298
slakr's Avatar
Anybody???
slakr is offline
Old 04-14-2007, 04:44 PM
  #299
lockmouth's Avatar
Here my Matrix TR all ready for the AIC 5.0 race April 19 - 21
As you can see from the pictures I have use the Lunsford Titanium turnbuckles all over.
I also used the Kyosho transponder mount to mount the transponder closer to the front.
My set-up:
Diffs
7000 / 20000 / 3000
Gene Diff Conversion
Shocks
Front
700 Mugen with piston #1
Mugen Red Springs
Rear
400 Mugen with piston #2
Mugen Red Springs
Front Suspension
1' Toe Out
-2' Camber
Rear Suspension
3T2S block
-2 Camber
Engine
Ninja .21 BO1
30% Byron
15t Bell
M2C 4 Shoe Set-Up
Reg. Soft Shoes
(2) .95 & (2) 1.0 springs
Brakes
AVID Phenolic
Wheels & Tires
Proline Maxx 23mm 1/2 Offset
Holeshots with Molded Foams
Attached Thumbnails CEN Matrix TR-dsc01749.jpg   CEN Matrix TR-dsc01750.jpg   CEN Matrix TR-dsc01755.jpg
lockmouth is offline
Old 04-14-2007, 05:29 PM
  #300
lockmouth's Avatar
Default Complete Lunsford Kit for Matrix TR
Here is the complete set-up with part #'s
Front Upper
Xray #353170
Xray #352150 x 2
Lunsford #1580 x 2
Front Steering
Lunsford #1480 x 2
Servo Arm
Xray #352460 ( Optional )
Xray #352670 ( Optional )
Lunsford #1064
Rear
Xray #353170
Xray #352150 x 2
Lunsford #1589 x 2
I've been using the Xray ends on the servo arm, because the stock setup binds bad.
This is a weight shaving an more bullet proof setup than the stock if you ask me.
Lunsford = A lightweight lifetime guarantee
*** This is not a must have for the Matrix TR. This is my personal choice***
