Team Associated 1/8 scale Buggy Info and Tips
#8476
#8477
ok so here's some bonehead stuff...
I went to put new caster bushings in my car this morning, and I realized i'd had them totally mismatched and apperently i've been doing it for a while. For some reason I thought that when you buy them in the little bag from associated, there were 3 sets of 16 degree... i don't have a matching set of anything.... front 18 back 14, front 18 back 16... and so on. I have the upper link set for 16 degree, so that has remained constant. I've noticed over the last few races that it didn't turn the same way left as it did right. This might be why, cuz everything else about the setup is on the money.
I'm gonna try and find a fresh set of 16 degree inserts at the track tomorrow (the shop is out of them). If the upper link is still in between the 2 cone washers, it's basically a 16 degree setting, with osme binding on the bottom, right?
i just want a set that matches
#8478
I'm having some trouble with the screws and bushings staying tight in the caster block. I've put locktite on them and they still seem to fall out. Anyone else have these issues? On my old rc8 I never had this issues. In fact, they never came loose at all. Whats up with this one?
Dylan
Dylan
#8480
#8483
#8484
Has anyone played with the foam compensator in the RC8B shocks? I remember something about it long ago. How are you guys running them now? Mine are set with 1/2 rebound now.
#8488
Fuel Tank
I have the original RC8 and just got back into racing last weekend. I have two fuel tanks that were sent to me last spring (2009) to replace two I had cracked around the lid. My engine tune was changing a lot,but never suspected the tanks because I thought they were "fixed". I started browsing this thread and noticed some are using other brand tanks still. Question is, was the tank issue ever resolved or should I be weary of the replacement tanks and also use one from another car. I got one from an 808 that I used while my AE tanks were being replaced by AE.
#8489
I personaly have not had any problems yet(knock on wood), and would probably replace it with the d8 tank its what i've heard people doin.
