Team Associated 1/8 scale Buggy Info and Tips
#8386
Can someone tell me where I can find the latest setup sheets for the factory team rc8b. Ive checked team asc site and there was only 2 on there. I know there are some newer setups out but I cant seem to find them.
#8388
what lipo battery is everyone using in there b
#8389
If you look at RC8 there are 2. If you look at RC8B there are far more. The sight could be far better on the set-up side. Then again I'm not the one keeping the sight up to date. Maybe it's a lot of work. It would be nice to see more in there.
#8391
These are the two they run:
Cav's http://67.199.85.166/racing/setups/r...lenge_2010.pdf
Maifield's http://67.199.85.166/racing/setups/r...rnats_2009.pdf
As for as us "average Joe's" we run a different shock package. 1.3 x 8 30-35w ae oil all the way around or Shane's 1.25 x 5 27.5 Losi oil front and 1.35 x 5 32.5 Losi oil rear.
#8392
What would you recommend for someone who has the Original RC8 with BB w/Ghea 1.3mm X 8 pistons? Lipo in Back. Will have the servo and battery tray in the future.
#8393
The team only has 1-2 setups they run everywhere. The only thing they change is the rear chamber link, shock oil and springs.
#8395
If you have those pistons I would use them for now. I would also upgrade to the new rear tower too. This is the biggest improvement by far! For everything else I would use Cav's setup. Shane's shocks would be better is you have some blank pistons to drill out.
+2
#8396
Go over the the left where it says select your buggy and switch that to rc8b. There's around 20 setups.
#8397
With the Original RC8 and BB w/Bronze spring I am having trouble getting the front down to bones level. It sits way high with no turns on the spring collar.
#8399
I will use my AE ride height gauge. I have around 35mm with no preload up front. The rear is fine.
#8400
