Losi 8ight building and setup >
Old 04-02-2009, 07:01 PM
  #8251
lowcountrytj's Avatar
Need some help fellas,I pulled the buggy apart for some cleaning and repairs,I bought new center front and rear shafts to replace the ones I have(dont have a pin press yet) I had some spares that came from a junked buggy and I started looking at them and dont know what I actually rcvd when I got the new shafts(ordered off ebay)The only thing I do know is the rear center has the knot in it.Does anyone know what the length is on the front center?
lowcountrytj is offline
Old 04-02-2009, 07:11 PM
  #8252
RETRO RC's Avatar
just measured a centre front unassembled with digital calipers
95.8mm or 3.771 inches
RETRO RC is offline
Old 04-02-2009, 07:26 PM
  #8253
Thanks a mill Retro,The one that is suppose to be the front is exactly 4" long from end to end...I think it may be an outer cv shaft?
Old 04-02-2009, 07:37 PM
  #8254
RETRO RC's Avatar
yep 4.037" thats a outer not a centre front
RETRO RC is offline
Old 04-02-2009, 07:40 PM
  #8255
Dang it,oh well --like I said before thanks for the help.
guess I will put the worn out one back in.
Old 04-02-2009, 08:11 PM
  #8256
dishsoap's Avatar
I put this on its own thread. Maybe I will get some more traction here.
I kinda need some adivse on what to change next on my Losi 8 B for performance. My problem is the back end. I cannot seem to get it tight and feels really loose in the back.
I am having a problem on the turns and getting it squared up to hit the straight. It seems that when going into turns the back end spins out and when coming of of turns its loose as well. I just feel like I have no grip and the buggy dose not want to plant itself to the ground as it keeps bouncing all around the place.
I cant hit the straight full power due to this.
Here is my current set up what should I try next to tame it down for more grip?
1) Shocks were just serviced with recommend weight
2) Sliver springs in the front and green in the back
3) AKA City Blocks Medium
4) Diffs front 5 middle 5 rear 2
dishsoap is offline
Old 04-02-2009, 08:13 PM
  #8257
bradfox2's Avatar
For the wingmount problem,
has anyone tried one of these?
http://cgi.ebay.com/ALUMINUM-Wing-Mo...ayphotohosting
bradfox2 is offline
Old 04-02-2009, 08:17 PM
  #8258
JEB21's Avatar
quick question,
Just about finished with my 8ight. What spares would you guys keep in the pitbox? Any parts that tend to break easier with this buggy. Nothing worse than hitting the track and not having a spare when something blows. The hobby stores near my local track doesn't carry Losi parts so let me know what I should have on hand. Thanks.
JEB21 is offline
Old 04-02-2009, 08:23 PM
  #8259
dishsoap's Avatar
Originally Posted by JEB21
quick question,
Shims
A-arms front and back
Hex Bolts
Tire Glue
Loctite
Clutch and Diff bearings
Clutch Shoes
Glow plugs mc 59
dishsoap is offline
Old 04-02-2009, 08:27 PM
  #8260
Integra's Avatar
what are the toe and anti set at ?
Integra is offline
Old 04-02-2009, 08:29 PM
  #8261
bradfox2's Avatar
quick question,
You need rear hingepins, a wingmount, a radio tray, and maybe 1 shockshaft if your up to it. I would also suggest the pins that connect the outrives and axles, they can shear or fall out.
bradfox2 is offline
Old 04-02-2009, 08:47 PM
  #8262
Suspended
Dishsoap: Try a softer tire, Losi cars really seem to like softer compounds. I only run M2 or similar harder compounds on certain tracks. I ran M3 Bowties when I was down there or maybe even Red Eclipses if it's drier. Also you should try wider hexes in the rear LOSA3532. This will lock in the rear a little more and not allow it to swing around as easily.
http://losi.com/Products/Features.aspx?ProdId=LOSA3532
http://losi.com/Products/Features.aspx?ProdId=LOSA7769R
Talk to Chuck or Casey if you see them and they should be a little more help.
CodyRothe is offline
Old 04-02-2009, 09:23 PM
  #8263
dishsoap's Avatar
Dont really know. And I dont really know how to change these up!!!
dishsoap is offline
Old 04-02-2009, 09:29 PM
  #8264
dishsoap's Avatar
Should I go with the 1/2 inch hex or the 2mm hex.
It looks like the 1/2 in hex is too wide.
http://www.amainhobbies.com/product_...ducts_id/16551
http://www.amainhobbies.com/product_...ducts_id/16340
dishsoap is offline
Old 04-03-2009, 05:54 AM
  #8265
Integra's Avatar
the 2mm is for buggy....the 1/2 is for truggy.
Integra is offline
