Losi 8ight building and setup
#7636
R/C Tech Elite Member
Should've bought a race roller! About 80% done with my fresh stock 8B kit and has the following issues
1. One of the diff cups is warped preventing install - luckily had extra from 8T spare parts
2. WTF a 8T front center shaft was included instead of the much shorter 8B shaft, found out after I installed the wrong shaft in - luckily ordered an extra one
3. Rear center driveshaft is too short!, Have to go to hardware shop and look for shims.
WTH is wrong with losi these days, my 1 year old 8T was immaculate.
#7641
Heres a great option. Right at $70
http://www.carolinasrc.com/Webstore/...idproduct=4930
Here is an EXCELLENT throttle servo! Just a bit more than the posted price range, at $89
http://www.carolinasrc.com/Webstore/...idproduct=4929
#7643
#7645
#7648
a question for anyone that has used skid plates :
Im thinking of putting a skid plate on my car that has about 1.5-2 mm worn off the chassis already. If i put a new diff case on the rear, it will stick out 1-2 mm, are the skid plates hollowed out where the diff case sits? Will the diff case sticking out prevent the skid plate from sitting properly against the chassis?
#7649
they arent hollowed out...so therefor would cause an issue with skids.....1-2mm wow...what kind of surface do u drive on ?
#7650
the nitro pit, minimum 2 chassis per year.. sometimes 3
