Losi 8ight building and setup
#6856
For those that purchased the kit; were your tires already glued onto the rims?
Thanks!
Thanks!
#6857
OFNA #10040 flywheel. It positions the flywheel and shoes correctly with the engine in the stock position.
I run the OFNA shoes (1 carbon and 2 alum) with OFNA copper 1.0mm springs.
OFNA 18 tooth clutch bell and clutch nut.
I like the 18-47. It seems to work everywhere and has more than enough.
This is 11.22 - 1 which is right at where the Associated factory guys are at.
Hope this helps,
TEX
Hope this helps,
TEX
Rod
#6859
Ofna #s...
Flywheel - 10040
Clutch Bell 18T - 10404
Shoes Silver - 10013
Springs 1.0mm copper - 10100
Then I also use 1 carbon black shoe.
I like this flywheel because it positions the shoes forward so the CB lines up correctly with the spur gear. It does this with the engine in the correct position.
I also like the Losi clutch but since they do not make a CB large enough I had to something else that would work.
Yes - This is an 18T CB to a 47T Spur.
Hope this helps,
TEX
Hope this helps,
TEX
#6862
here is a quick video of a lap at our local practice my buddy took of me a couple months ago. Decided to try and apex the back elevation change a little too close and went on the lid for the 2nd lap lol.
http://www.youtube.com/watch?v=A5gg8Bqu93A
#6863
Nice track man...where about's is that ?
#6864
So whats the is in the stock 8ight diffs for gearing if the 8ight-t has 10-43
#6866
so to get the truggy gearing just change the input shaft???? and if so why is the gear thats on the diff have a different part number for the buggy and truggy?
#6869
