Losi 8ight building and setup
#2492
voltage regulator
Anyone know who might have this in stock. Amain hobbies is the only online store that I could find it on and they are out of stock.
Muchmore Li-Ion and Li-Poly 6.5V, 7A Servo Voltage Regulator
[MGL-MRG-7A]
[MGL-MRG-7A]
#2493
Originally Posted by freefallmarine
Anybody really tell the diffrence between the standard pro-line wing compared to the high downforce?
I have been running the Himoto wing and versus the proline wing it last far longer. Performance wise I am not good enough to tell much difference.
#2494
[MGL-MRG-7A]
[MGL-MRG-7A]
Stormer sells them, but they are out of stock on the 7amp regulator. They have the 5 amp and 3 amp in stock.
#2496
TIRE BALANCER
IS ANY ONE BALANCING THEIR 1/8 TIRES AND WHEELS. IF SO WHAT DO YOU USE. THNX
#2497
Originally Posted by G Mills
With out the time to go through the whole thread, could someone outline the necessary mods that need to be done? Thanks.
#2498
Originally Posted by rezenclowd3
Only one "modification" needed. Put a 10th scale shock o-ring under the battery box and instead of using the supplied screw, use a 1/2 inch long one, and screw it in just till it is flush with the inside of the battery box. This reduces vibrations to the throttle servo. Other than that, nothing is needed as far as after-market parts.
#2499
Hiya, i think this has been asked before somewhere in the this thread, but what is the correct rating of the shock springs?? Red, Green, Black and silver. Rating from hardest to softest?
Cheers, Leigh
Cheers, Leigh
#2501
i use this and shoe goo for weight, if you need a lot of weight use a old screw in the shoe goo.
http://www.bluegrasshobbies.com/bg/c...roducts_id=471
#2502
HOW DO YOU ADAPT TO THE PROP BALANCER?
#2504
Has anyone noticed that the front end of the car gets a sloppy after just a little use?
#2505
