9Likes
Kyosho Inferno 3.0
Kyosho Inferno 3.0
Hey Guy’s
So coming up on a gallon VP25% through the .21 K.E. Engine, I just bought a connecting rod for it. Thing runs perfect super powerful and never has been over 270 Fahrenheit. Looking for opinions of when I should replace the rod for extra insurance. So surprised with how well the engine runs, the ease of tuning and amount of power from an RTR.
TIA
TIA
in a properly tuned engine connecting rods last gallons of fuel. piston and cylinder will typically wear before the rod needs to be replaced. replace the rod only if it's worn out and sloppy. or when you change the piston and cylinder throw it in. you'll know when to change the piston and cylinder cause you won't have compression
Thank you for the information. I was under the impression the rod would need to be replaced first. Thank you for the replay.
Hey Guy’s
TIA
TIA
High temps can mean the engine's running a little lean, too. More oil is not always the answer to high temps. If you're not comfortable at 270 a couple clicks on the main needle will help. Anything over 10-12 % oil is probably part of the problem. I'm going to get yelled at for saying that.
Higher temps can also come from a too hot plug and/or too much nitro content.
Stop the crap about the more oil advise, also too much oil can give a higher temp.
