9Likes
Nitro engine exhaust
Hello all.I’ve been breaking in a new engine in my tmaxx.When I put my exhaust pipe on the engine.I did not have any gaskets.should the exhaust system be sealed?The engine does have a bit of erratic idle but other then that no issue.
Yea there should be a gasket.
and another thread for the TMaxxx... are you going for a record?
What a pleasant bunch you guys are. Way to welcome the new guy. Op, Yeah it should be sealed. The exhaust provides pressure in the tank to make the fuel flow better.
but he is asking a nitro specific question, not something specific to a monster truck so he’ll probably find more help here. It prob should be in the nitro engine sub-forum.
To come back to his earlier questions... Yes, no gasket will give a leak. Because some pressure from the exhaust is going to the tank acting as a fuel pump you want the pressure predictable so you can tune the engine to it. With no gasket the vibrations will give a variable leak and so a variable pressure loss to the tank with which you can not get a stable tune on the engine.
Thers should be an o-ring between the engine and header pipe for 2.5 and 3.3 engines.. A coupler with zip ties between the header and tune pipe. Stock plastic pipe or optional resonator pipe. No gaskets unless you are not using a .15 Traxxas engine or other brand engines. Use RTV sealant or a gasket. Yes the exhaust should be sealed to pressurize tank.
In another topic I mentioned that it is nice to know I have a follower, now it seems you are more like a stalker.
I gave some explanation in this topic, and what did you? I only see some nasty text to me, showing your overpriced T-Maxx and no help.
I hate anything Traxxas but I will admit that your's is pretty sweet looking. Honestly you should have made your post on the nitro engine section where you will more than likely get more responses. Some folks get upset some don't it's just the way it is here, but that do have a point to a point. Also download the manual for your truck if you haven't already so you can gain knowledge of your truck w/ out having to ask questions about certain aspects of the truck. Not saying you shouldn't ask questions here but something basic like what you asked is something you should have known already. Not nagging but it is a mechanical device that requires a self knowledge base and believe it or not will make the hobby much more enjoyable. Having exhaust gaskets is a common sense thing but I do understand some folks aren't too mechanically inclined when it comes to rc cars and how they work mechanically. Again I'm not preaching here just giving info.
