Losi 8ight and 8ight T RTR
#16
#17
from the second pic, it looks like the droop screw is hitting the chassis.
#18
I drop the car from a low height, then measure with the Losi gauge (as pictured below). Even if I screw the collars right off the thread it goes from 23mm to 24mm. And you'll see in the pics that I even moved the bottom of the shocks in and this didn't help much. I do not have a droop gauge yet, but if I Iift the front there is plenty droop, so that is not affecting ride height. Next I will remove shocks and check for any binding in suspension, but when I checked the oil I'm sure they felt free.
#19
#20
I purchased recently the 8IGHT-T RTR (loving it) .. I also found that the default shocks are not the greatest .. however, what I did, rather than spending more that $100 to replace the shocks completely .. Emptied out the existing oil in the shocks and replaced it with the default weight of what was being used for the 8IGHT-T 4.0 roller .. so 37.5 wt in the Front and 32.5 wt in the Rear.
This certainly made a difference as you'll see from the video : h t t p s://youtu.be/Vx1tkck1Sd0 (apologies) .. I'm unable to post URL's at this time - no enough posts - remove the spaces
