Tekno MT410
#1051
I had the same question there as well - I ended up installing per manual and Tekno confirmed that they changed the orientation for more clearance so that the screw end doesn't rub against the arm.
On the droop screws - I ended up getting TKR1238 (which are the same as the ET and EB I believe). So the button head ends up at the bottom of the arm against the chassis, with the adjustment accessible on the top side of the arm.
HTH!
HTH!
#1052
#1055
These trucks are ridiculously tough. If I had done to an Arrma what I've done to this truck, I would have bent the chassis in half, broken every shock rod end, bent the steering plate, taken out half of the wheel bearings, broken several suspension arms, and frozen the steering servo. This list, although hypothetical, is representative of what I've seen of my friend's experiences with a Senton.
The Tekno has suffered a body that has been beat to death, I had a plastic shock cartridge cap break, and I've pulled the shock mounts through the plastic body mounts several times. Color me VERY impressed!
My track 1/8th scale vehicles are Mugens which are very tough, I do believe the Tekno is even more so (particularly the suspension arms).
Jay
Jay
#1057
Not exactly a nose landing, but I've run mine into the shed in my backyard twice, dead square hits at probably 30mph and the only damage is to the body.
I've also run it into a couple of trees at a good rate of speed, no damage.
The main weak point on mine so far has been from jumps I land poorly. I've got a 3ft tall ramp setup and bad landings have so far resulted in:
The rear shock mounts pulling through the body mounts (seems to be common lol)
The right rear shock shaft pulling out of the rod end (rod end is stripped, have a new one going on tonight)
The bolt and bearing coming loose and falling out in the grass on the right side of the bellcrank. I've added more loctite and really torqued it down since then, seems to be good now.
#1058
Some people have broken the stock plastic brace and some people like the rock solid support it offers especially when combined with the shock tower brace. It's overkill for a lot of people but serves a purpose for the extreme crowd.
#1059
Jay
#1060
Jay
#1063
Fierce RC Solutions is having a sale on the MT410. Using the coupon code it can be yours for $357 shipped! That's the lowest price I've seen.
TKR5603 ? MT410 1/10th Electric 4×4 Pro Monster Truck Kit
396Likes
