Tekno MT410
#1816
No everything just transfers straight over without a problem. The MT410, EB48, SCT410 and ET48 all have the same chassis layout, just different lengths that's all
#1817
I have the T-Bone tubular style front bumper on mine already, after checking out the new rear bumper, I HAD to have it, so it's on order. Very cool, and realistic appearing.
I'm painting up a Baja Bug body (I have several different bodies) and would have had to cut the engine detail portion of the body out using the stock rear bumper/support. The T-Bone bumpers are much flatter across bottom, I'm fairly confident this will fit with the full, intact body. Anybody with pictures of their MT with the new rear bumper?
Jay
Jay
#1818
Hey guys, I've been following (slowly) along with the build thread and wanna give a big THANKS to all that give tips on builds.
My setup.. Monster Truggy.
-MT410 chassis for now..soon M2C truggy chassis.
-3.8 MX BAdlands and truggy size wheels
- Tekin Gen 3 RX8 and 2000kv truggy motor
-SMC 7200 4s lipo
- Truggy Frt. & rear shock towers...I highly recommend this change up. Better stance (wider) at the camber links, beef'r than stock by far!
-M2C Diff cups F,C,R...20k,20k,10k
-Savox 1270 servo
- All chassis supports
-Aluminum shock caps, spring nut setup emulsion only.
-Low pro truggy wing
So much fun to drive and race!
-SMC 7200 4s lipo
-Savox 1270 servo
#1819
-SMC 7200 4s lipo
-Savox 1270 servo
-SMC 7200 4s lipo
-Savox 1270 servo
#1820
I'll try to get'em up tomorrow.
My motor will be here this weekend. I had the Gen1 2000kv got it swapped out to the Gen3 2000kv after a issue arose with the Gen1 motor.
I also run the Tekno Truggy body mod'ed (shortened) for the MT410 chassis. Basic flat white color with sicker on her.
#1821
Side view.
She's setting high when not loaded..
Where's the beef? Motor is going in tomorrow!
look at the difference in the towers!
Must change the tower!
Nothing fancy with paint yet.
Aluminum emulsion caps getting modded.. Plastic ones are solid for now.
#1825
I can't get the rear shock shock length to be 135mm when using the manual's setup. It's noot even near the 135mm. Any idea?
Also, is there any body that fits and goes low enough to reach the mudguards? I tried 2 of the ones that are supposedly compatible and they don't really fit or are clearly now high (low...) enough.
#1827
What did you change to the stock shock setup (or other things like hub extensions or ...) to not damage the shocks on hard landings and avoid them becoming fully compressed before the chassis absorbs the hit?
#1828
I see you are running 0 offset giant tires. I'm trying the same but can't get chassis slap befor the shocks bottom out, which I'm sure is a recipe for disaster.
i agree with you : if the chassis can't bottom out, something will break. but it seems that the mt410 did a good job so far, maybe thanks to the thick tire/ small rim who can compress a lot
#1829
it's not my video, it's "ABC kid" . he will reply to you in the comments of his video if you post you Q there.
means you're limited to them (discontinued), badlands (out of stock atm), most Traxxas e-revo tires (ugh) and not much else I can find if you don't want to risk destroying your shocks.
nice. Should have bought an Outcast.
#1830
For future reference: there's no chassis slap possible with anything bigger than the Shockwaves.
396Likes
