Tekno MT410
#1651
Tekno Dune Buggy with the hinged cage from the Losi TEN-SCBE.
I love the hinged design!
I made a template to line up the holes on the rear tower.
I used a M3 center locating punch to mark the holes.
Drilled nice and straight.
Connected.
I used the existing hole in the front tower and used the Losi post.
I drilled a hole right in the middle of the front support for the post.
Connected.
A little extra width can really help keep it on its feet when you’re cruising at ridiculous speeds.
#1652
Quick question. After reading and going back and forth on trying to make up my mind on my next project
What are the absolute must have upgrades? Servo arm,steel center diff gear from what I’ve read are definitely on the top of the list.
What’s the largest motor that will fit? Since this truck is lighter in what I mess with a 4038 1700kv motor should fit or maybe a 4038 1550kv Tekin be enough?
#1654
Yeah I’ve yet destroyed my mt4’s plastic gear so I can leave that off.
I got a airtronics rx/tx a Hitec 7050th and a sanwa servo Tekin gen3 rx8 and half set of trencher x’s that I was gonna use on other build
Is the truck about as big as the mt4? If so then I’m down
Also best deal to get one at? No local HS carriers in my area
#1662
Thanks for doing this Overkill!!
Do you have an active list or are you just going to post them when they are available?
Can I preorder?
Can I preorder?
#1665
Ok fellas heat update. I added a dynamite 1/8 motor fan and its beyond good now motor was at 112 degrees after 20 mins bashing on 17t so i went up to 18t and im gonna leave it there.
