Arrma Outcast 6S 1/8 "Stunt Truck"
#121
#122
I like how the Nero drives. And have what should fix, improve the rod end issue I've had.
#123
The Nero chassis is not a beater set up!
The out cast is a tried and true platform.....stick to what works for application.
You can take an 1/8 buggy and pound it till the cows come home and they for the most part take it.
OUT Cast is that with big arms and tires.
The truth will set you free!
#124
#125
Sheer abuse is the better way to word it.
That design has too many moving parts for massive abuse.
It is a bash truck but its limited by its design.
#126
FYI, the Backflip wheels/tires are now in stock @ Tower:
http://www3.towerhobbies.com/cgi-bin...&I=LXGFDF&P=ML
I ordered a few sets last night. I'll be putting these on Big Rock full time now.
#127
Such a happy truck. Always wanting to stand up and cheer. The new springs look like a tremendous improvement.
I'll be needing a set of those Backflips for my Fazon but really like the way the Pincers feel in the grass. I get all the speed and nice drift action without all the flipping and traction rolling.
#130
Trout
#133
How is part interchangeability among all the Arrma cars? Kraton, Typhon, Outcast, Neros, etc..
I think if I were to get an Arrma it would be the Kraton, as it's cheapest. I like the Outcast's looks (and tires) best, but I think I'd rather have the longer chassis. Aren't they basically the same under the hood except for the chassis length? Is there any part crossover whatsoever with the Neros, buggy, Senton, etc?
#135
The taller side guards from the Outcast are plug and play on the Kraton and Tailion. They will not fit the Senton because of the body side protectors are integrated with the side guards. They also will not fit the Typhon because of the body design.
The new front dirt guards (mounted to the front builkhead) are also plug and play for everything but the Typhon.
The updated battery tray requires slight modification to fit all the models, but you can use the existing parts to make it fit.
Obviously, none of the Kraton, Typhon, Outcast, Talion and Senton items will fit the Nero class of vehicles. ALL of the Nero class vehicles, the Big Rock, Fazon and Nero's can share all the parts as bolt on's between each other however.
