E maxx brushless FLM build!
#61
Your t bone doesn't look as wide as mine was where it bolts on. I cut it down a little and it fit. I tested it out today on 4s and made it pretty much all the way through the packs. Right at the end the rear diff cup grub screw backed out again. I'm going to red loctite it this time. I have some 3s packs charged for tomorrow to really beat on it. Did a good bit of cartwheeling and bad jump landings and nothing happened.
#62
Well got it out today on 6s and busted a rear diff. Did a standing backflip and it went (I know I know but I couldn't help myself). So what's the best way to go for a drop in diff on the flm hybrid bulk? Vorza diffs?
#63
Rock-rod on the traxxas forum runs those votza diffs, he'd be the man to ask about those. I run the hyper 7's and they have been great to me. The vorza iS a spiral cut gear, the hyper is beveled.
#64
#65
I also run the hyper 7 diffs in my flm hybrids. I also have run the hpi trophy Truggy diffs. Both just drop right in. May need. Couple shims but no biggie. Remember tho if you use the hyper 7 diffs make sure they are the tq not the ss
#66
#67
Not sure what the difference is wish I could help there. The spiral gears is more like a 1/1 car and probably wouldn't like going in reverse but other than that I don't know. I can speak for the hyper 7's and they are a drop in like slapjack said. And also yes make sure you get the "tq" model diffs if you go that route. I'm sure the vorza diffs would be fine but the hyper can be had cheaper.
#68
#70
#71
Ya they can had pretty cheap lol. The thicker fluid will give you more "drive". More of a limited slip affect like a real 1/1 car. Thicker fluid will give you more 4wd over a thinner fluid.
#72
I wasn't expecting them to be that cheap, pretty sweet! I'll pick up some 50k fluid to fill them with, thanks for the info. I had some crappy he tools that stripped the mip grub screws for the axle to the diff. Not looking forward to getting those out. Anyone know where I can get just those grub screws?
#73
Spiral cut gears have a circular shape to the teeth so on the ring gear the teeth start at the center but follow an arc to the outside of the gear. The other kind is straight cut gears where obviously the teeth are straight. Both are considered bevel gears it's the cut that's different.
Spiral cut gears can be quieter and some say stronger due to the spiral having more contact area. The downside is the spiral causes the gears to want to separate from each other increasing loading on the bearings and requiring more frequent checking and adjustment of the mesh (shimming) in RC vehicles.
#74
Also remember if you use red locktite, in which case I do, be sure to apply heat before removing anything with red locktite. Will keep you from stripping screws. And fine tools also help, cheap Allen's are not the best choice
#75
Ya good luck. I did that a while back and ended up using a milling machine to get it out. That hardened screw is tough! If its the ones attached to the drive cup then use the updated screws. Part # 99060
