tmaxx electric conversion >
Old 12-11-2014, 11:09 AM
  #31
Trader Rating: 14 (100%+)
I just measured mine and it's 73mm long
Brandon1977 is offline
Old 12-11-2014, 11:12 AM
  #32
Old 12-11-2014, 01:10 PM
  #33
Holy crap thats a big motor. Is that a tattoo? If you can you could always make your own mount and mount the motor higher towards the top of the spur and put the battery under it
rc car freak is offline
Old 12-11-2014, 02:03 PM
  #34
Yeah, I'm thinking about buying a dremel and making my own mounts from now on. I know a guy that has a tig welder for welding aluminum. Aluminum is a soft enough metal that can be bent just can't bend it too sharp or it will break. And yeah I have a sleeve tattoo on my left arm
Old 12-11-2014, 10:47 PM
  #35
Trader Rating: 18 (100%+)
I didn't think it was longer than a 1515, that's why I did a quick search and grabbed the measurements from a vendor page. Either way only the 1512 2650kv is shorter than your motor. Glad we got that cleared up! Lol
And this is the truck I was referring to in my previous post.
Originally Posted by vanquisher
Installed the battery box and a 20T pinion and let it rip. Now we are talking. It has some speed now and the rearend squats hard. Surprisingly the trans held up just fine, but I wasn't getting all stupid with it either because it's not mine and I know how to respect 6S power. Of all things, the slipper gave me problems because the nut kept loosening, getting the steel spur so hot that it could have been used as a branding iron. I put some Loctite on it so that should be a non-issue. I'm gonna try a 22T pinion, box it up and give it back to the owner. Thanks for all the help and info guys, it was appreciated.
Final configuration. It's tight, but it all fits under the narrow Proline 50 Chevy P/U body.
Overdriven is offline
Old 12-12-2014, 12:49 PM
  #36
Cool. And Brandon i dont have a dremel what i do it get 1/8th inch aluminum, cut it with a hacksaw, bend it to a 90 degree angle with a vice and hammer drill a 1/2 inch hole for the pinion then drill the other holes mount the motor, mesh the gears and drill through the chassis and bolt it. I did that on my brothers electric tmaxx he bought for $100 so that there was room to put a battery
Old 12-12-2014, 06:51 PM
  #37
That's a good looking truck. But I put my truck through the mess. I rip it through parking lots and ride 100' wheelies. That battery pack and the wires coming over the top are too close to the spur gear for my liking.
Old 12-12-2014, 06:53 PM
  #38
I do like the battery holders though. Is there a link to get those? I need to lower my center of gravity and I have an idea for those
Old 12-12-2014, 08:10 PM
  #39
Just get Velcro straps and bolt them to the chassis
Old 12-12-2014, 08:42 PM
  #40
Velcro loses its ability to vel to the cro after awhile. Those are made up words but you know what I mean. I want my batteries secured and protected. I'm gonna try to devise a way to mount them on the bottom of the chassis
Old 12-12-2014, 09:04 PM
  #41
All i did to mount the tranny was cut a few aluminum peices and bolt them down. If you want room to mount your batteries on the chassis its not hard to mount the 3905 tranny
Old 12-16-2014, 12:27 PM
  #42
Hey brandon you should just get an emaxx tranny ill link the ebay shop i got mine from later. If you want i can mail you peices of aluminum like the ones i cut so you can mount it all you would need is a drill. Also how did you make your battery mount
Old 12-16-2014, 09:03 PM
  #43
Either the Ofna or the Hobao SCT trucks use a similar tray that stands the battery on its side like that. That may be them in the pics of the Supermaxx but I'm not 100%
Old 12-16-2014, 10:32 PM
  #44
I made my battery tray with lexan, heat gun, and a metal box. I heated the lexan while it layer against the 90 degree angles of a metal box and used oven mitts to pushed it against the edges for sharper bends. If you heat the lexan too much it'll bubble and look like crap. So far the black tmaxx trans is holding up pretty good. I think the main reason people shred gears is because of no lube. I always see dry gears in pictures of shredded gears. Dry gears makes for hot gears. Heat makes plastic soft....
Old 12-17-2014, 05:26 AM
  #45
I was suggesting it to save room to lower your center of gravity. I bought it mainly cuz the tranny i got with the truck the gears could have almost been bushings they were so smooth plus after the slipper clutch and foc and single speed conversion it would have costed more
