shock help please !!!
wanted to know id it worth it to up grade the shocks on my truck ... is it worth it to do this ? i run the truck on and off road at high speeds ... heard so many pros and conds figure id trust you guys out thier .. if thier is a better shock than just replaceing them with with stocks ones please let let me know links and prices thank you well appreciated .. oh one more question if i stuck a 454 engine in a stock last chassis can it handle it or will it eat itself up ??
No one died in here, as far as I know it comparing to some other sites
Shocks are shocks n it shud b functioning properly with setting. Shocks shud meet ur mode of play or requirement. Some wants super strong bec mode of play is extreme, some just as precaution insurance just in case, some just for d bling bling of it, some has thick pocket n wants d best n most expensive and some simply like stock shocks bec it mets their requirement n mode of play.
If u don hv any issue wt stock n happy wt it, then I suggest to leave it as is. Upgrading ur shocks is always better if u got the bucks n or meet what u want out of it. I upgraded mine cuz stock keeps failing on me.
Agree - drop integy from ur list if u want to upgrade ur shocks for performance n durability reasons. It is expensive but crappy aloy grade with less than adequate plunger design.
then i suggest to go for stock alloy shock body and top cap...the HD alloy would be best. integy drop if..looks nice but not for hard bashing/extreme
For savage, i also use the LST2 alloy shock on my savage for track bashing. but if i want to do stunts/backflips and all, i change mine to stock savage big bore shock or savage big bore alloy shocks, most suited for stunts and all...
if the stock lst2 shaft or the stock tini lst2 shaft keeps bending or breaks, substitute/change the shock shaft to the integy msr ones with slight mod..they are much thicker and stronger,, i never broke or even bend it even once after some years.
been wanting some lst shocks for my mta4, i went with the tt alloy shock bodies & caps & new bladders, piston & they've been good. lst's look nice n big volume. Are they as good as they look ? Look like handling's good on tracks with them, on the lst.
Tony
Tony
