E Maxx question >
E Maxx question
E Maxx question
Old 02-14-2012 | 01:02 PM
Default E Maxx question
Are Robertson Racing slipper clutches good products ?What about a roll cage for e maxx worth while
bryanmiller27 is offline
Old 02-14-2012 | 01:42 PM
Dhthmn114's Avatar
RR slipper set-up is leaps and bounds over the stock slipper.. I have it on my maxx.. Would recommend it 100 times over... Mine was like $27 through Tower Hobbies...
Dhthmn114 is offline
Old 02-14-2012 | 01:43 PM
ckblood05's Avatar
you mean robinson racing? yea i use all robinson gears and slipper on my t maxx. yes get a cage from rcraveninc on ebay. just type in e maxx cage.
ckblood05 is offline
Old 02-14-2012 | 02:14 PM
RCaddict0's Avatar
O' to be a newb! lol "Robertson RACING" I was new once myself. But the RR products Ive used where top notch. Been running stock slipper in my Maxx BE since day one. No issues
RCaddict0 is offline
Old 02-14-2012 | 03:25 PM
Robinson Racing stuff is freakin great. I've got a ton of pinions made by them, and a Gen3 Slipper in my Maxx. Awesome stuff.
WindDrake is offline
Old 02-14-2012 | 03:52 PM
ckblood05's Avatar
i agree 100% i have all robinson gears in my front & rear diffs, the robinson all steel tranny kit, robinson 58t spur gear, robinson slipper, robinson heavy duty slipper back plate, robinson 22t clutch bell, robinson flywheel. i love there products!
Old 02-14-2012 | 05:36 PM
mdw8778's Avatar
I just built a emaxx with rr gen3 slipper and it is louder than I expected. How tight should I go on the spur? Truck is "jumping" from a stop with little throttle. Any ideas? Thanks.
mdw8778 is offline
Old 02-14-2012 | 05:54 PM
I set mine up to be as tight as I'd need in order to wheelie from a stop, but not enough to backflip. It's pretty tight.
If your truck is jumpy at low throttle, can you turn your motor over by hand, or does it sort of magnetically click as you turn it? My motor has a real stiff, chunky turn to it, so it's loud and "clicky" at low speeds.
The gen3 slipper is loud. The metal rings. Nothing you can do about it.
Old 02-14-2012 | 06:10 PM
mdw8778's Avatar
The motor is very hard to turn by hand and it does have a click to it. Is that normal for the emaxx mamba brushless? Thanks for the advice.
mdw8778 is offline
Old 02-14-2012 | 06:20 PM
Normal. It'll soften over time, but that's just how some Brushless motors are. My two blue-can Kershaw motors (4 Pole) are really stubborn like that, whereas the Leopard in my Muggy is smooth as hell.
I was curious as to what causes it, Wikipedia calls it Cogging (No Current) Torque. Looks like lower pole motors will have a more pronounced case of it, as well as having a lot to do with construction. Though it's very clearly presented, more cogging torque = higher running motor torque. Not really too bad of a thing.
For the Scientifically Minded: http://www.gotwind.org/images/cogging.pdf
Old 02-15-2012 | 04:47 AM
Default EMaxx
Thanks for the input and being easy on the newbe!I did mean robinson racing.I should be getting the slipper unit in mail today will the truck just break the next weakest link after the metal spur is installed?I checked out R/c raven they have a roll cage for E Maxx and a kit that has skid plates and metal front and rear bumpers do you guys think those are good products.From what i hear i am gonna be replacing alot of parts on this monster should i use rpm plastic or go with alum. stuff as i break it .Thanks for the help.
vxl Stampede 4x4
vxl Slash 4x4
Spartan Boat
E Maxx Mamba
Old 02-15-2012 | 07:21 AM
sm_bailey77's Avatar
Stick with plastic. A lot more forgiving in crashes than aluminum unless you just want a show truck.
sm_bailey77 is offline
Old 02-15-2012 | 07:33 AM
not a show truck so rpm stuff?even bulkheads?
Old 02-15-2012 | 07:49 AM
Not sure about bulkheads but stuff like arms and shock towers stick with plastic.
Old 02-15-2012 | 08:24 AM
Accordman's Avatar
i understand why they are telling you plastic, but as you become a better driver get what you like. i havent broke anything on an RC car in a few years and almost every one of my cars gets the full metal treatment.
Accordman is offline
