The best brushless motor for lst2
Most MT motors are 2200 or lower kV. Is your 2300 an 1/8 Scale motor, or an MT motor? The Monster-truck motors tend to be significantly larger then the regular 1/8 buggy/truggy motors. If you're using a buggy motor, that could be the explanation for the heat.
Personally I run a heavy Maxx on 2039kv. Your LST2 is similarly humongous, and would probably do well on 2000kv.
i would say the 1717 would be the best one i think.
not to hijack, but has anyone used a tenshock x802 in one of these trucks yet?
CC 1515 with 4S or 1717 with 6S are the best combos. Keep in mind the Kv/Motor you use is also affected by the batteries you use, i.e., 1717's are great with 6S but a 1515 will run hot with 6S. Gearing and tire size are also crucial. It's not just about the motor, it's the whole package. Motor, ESC, Batteries, Gearing, ect . . .
