Brushless Emaxx FLM Build/ Advice Thread
#76
maybe i'll find a machine shop locally that can polish everything for me...no offense but James = lazy
#77
Moondog, great work polishing. That does it, I'm polishing one of my other flm chassis'. Flm stuff always has a pretty noticeable machine finish, I've never polished it because I new it would take a while to get it smooth. Yours looks too good though so I'm doing it, eventually.
accordman, thats the way to do it if you can find someone to polish it up get it done. It is nasty work and you will be covered in black aluminum residue when you are done. I am just a sucker for making myself work three times as hard as i should.
#78
nah lots of kudos to you, i just dont have the time or the tools to do it myself
#79
Accordman, if your serious about getting your stuff polished don't go to a machine shop. I'm a certified cnc operator (machinist) and you don't want to pay machine shop hourly rates for just polishing. You can see my gmaxx thread where I polished that stuff. I'm going to polish a flm chassis this weekend hopefully, if your really wanting yours polished I will send you pics when I'm done. If you like what I do I will do yours for you, you would just have to pay shipping.
#80
shippings no problem at all. i'll def be on the lookout
#81
Ok man, I'll send you pics when I get done, hopefully that will be by the end of the weekend. I will pm you and keep you posted.
#82
For batteries, if you're using hard case lipos you can get away with foam underneath (I cut up a mouse pad for this) and velcro straps. Whenever I ran soft packs they got damaged so I now use a set of battery boxes from kershaw bolted to the chassis. The zippy flightmax 5000mah 3s lipos fit like a glove.
#83
Melon, thanks for the heads up on the batteries. I will have to look into the boxes as well
#85
all the remaining parts that needed to be ordered have been, so hopefully next week i will have a running truck or if i am lucky this weekend
#86
started doing the deed of polishing the bulks tonight. It is not nearly as bad as i thought it would be. So far i have got one bulk completely done and a chassis rail. Here are some pics but it doesnt show up nearly as good on camera
the rear one has been polished
same the rear one has been polished
the left one is the polished one
I will get some better pics in the sunlight this weekend. I dont get off work till after it is already dark.
#87
you can tell pretty well. I like it alot. keep up the great work man
#88
thanks man, well i took a break on the polishing but then i saw my servo laying over on the bench so i decided to strip the coating and give it a little polish up. The upper part is textured and i liked the look so i left it that way instead of smoothing it out.
and after
and after
#90
thanks melon, where are you at in virginia we may have to meet up and go bash these things
