"3s lipos for Savage Flux" >
Old 01-31-2012 | 06:53 PM
  #16
IH8VTEC's Avatar
Originally Posted by Duster_360
That's what I did, a pair of 2S and 3S 5000mah 25C lipos. Now I can easily run 4S, 5S or even 6S if I want to go crazy again.....
What 3s do you use, are they hard case lipos? Do they fit the stock battery box?
IH8VTEC is offline
Old 02-01-2012 | 05:56 AM
  #17
LaTuFu's Avatar
You realize this thread is 8 months old, right?
LaTuFu is offline
Old 02-01-2012 | 06:07 AM
  #18
IH8VTEC's Avatar
Yes, and I also realize people are not unsubscribed from threads after 8mo. Either. This question is currently being asked (by others) in the Flux thread so I thought this info might be useful since people are still asking the question, 8mo. later! If you prefer I can start another NEW thread about the same topic and clutter rctech with more disturbing cats? Seriously that cat is creepy.
IH8VTEC is offline
Old 02-01-2012 | 06:56 AM
  #19
LaTuFu's Avatar
No harm done. I just like having an excuse to post the zombie kitteh.
LaTuFu is offline
Old 02-01-2012 | 07:08 AM
  #20
IH8VTEC's Avatar
Default warning; this post composed after a monster eng drink.
Just when I thought I was up on my memes. At least you gave me something to dream about on my flight.
I found another thread where Duster was talking about his lipos and it appears at one point he was using Neuenergy if I remember correctly. I did a search and only found soft packs. The search continues for a hardcase 3s lipo preferably 5000mah and 30c. I found one at hobby king but the specs on the website show it being 1mm wider than the battery box. It may fit if the measurements are correct, if it's any wider I don't think you could shoehorn it in. Ultimate goal is to run 5s and sometimes 6s. I guess the mah have to drop to 4000. No biggie I guess.
IH8VTEC is offline
Old 02-01-2012 | 07:36 AM
  #21
LaTuFu's Avatar
What are the Flux battery compartment dimensions? I have no trouble fitting a 8200 mAh LiPo in the Revo battery compartment. It is a softcase, and it's pretty snug, but it works great.
The GensAce 3s batts should work well, as well as the Turnigy Nanotechs. But I don't own a Flux, so I can't say for sure. I just know what has worked in the Revo, which has a similar size compartment, afaik.
LaTuFu is offline
Old 02-01-2012 | 07:47 AM
  #22
IH8VTEC's Avatar
The best I could measure and be fairly certain a batt would fit is 208mm x 51mm x 31mm.
Anything hardcase 3s I've found needs to be less than 4000mah or of lower c rating and thus not up to the task. I'm figuring off hpi recommendation of 150amp rating. 4000mah would have to be 40c. Soft packs solve the problem but I'm hesitant to run like that. I thought batteries would be easy. I'm looking into kits that bring the lipos in board, I would run soft packs then.
IH8VTEC is offline
Old 02-01-2012 | 08:08 AM
  #23
go 6s. you can dial it down with a castle link or just learn/use throttle control
roost610 is offline
HTML code is On
