Tmaxx reverse
#16
You'll need something to use as spacers. I used a few cents worth of aluminum tubing, another guy here used plastic tubing, another used washers, and a 4th used electrical tape.
Hey it worked! And we all used a small grub screw to secure the gear to the shaft. There are lots of ways to do it, just depends on what's available to you, and whether you feel like doing it or not.
The 2nd pic shows the parts you'll be discarding.
This is how the gears lay in when you're done.
Hey it worked! And we all used a small grub screw to secure the gear to the shaft. There are lots of ways to do it, just depends on what's available to you, and whether you feel like doing it or not. The 2nd pic shows the parts you'll be discarding.
#18
