T/E Maxx Thread
#602
I extended the wheelbase with Unlimited Engineering Racer-X suspension arms. The tires work well and get decent grip everywhere! What I really enjoy about it is the extra ground clearance, this thing just floats over rough terrain and thick grass. The rims are Proline line desperadoes, half inch offset with 17mm hex
I did have to up the diff fluid to 100k or more. I think filled the rear diff with some 100k and put a little 150k in there too.
#603
Hi Guys, I need help. am looking into buy new tires for my tmaxx 2.5 but what parts do i need to upgrade for the drivetrain clutch bell and gears, I dont know which ones to buy and the tires that am buy are proline BIG JOES. Thanks for the help.
#604
http://www.ebay.com/itm/4-Traxxas-1-...item1c3eb026b8
there is a truck you can use so thet you don't need to get all new axle carriers.
http://www.ebay.com/itm/17mm-aluminu...item48644bc66c they just replace the old ones (if you don't already have)
the diffs are a mist to upgrade. they just drop right in. but you need the one with 4 screws.
http://www.ebay.com/itm/2-TRAXXAS-49...item20db2fa1a6
as for the clutch, just go down 1-2 teeth on the bell and your good to go.
#605
I just built a EMaxx from the ground up, film chassis, rpm all the way, stainless steel screws, trenchers and steel cvd's, and mmm2 brushless 2200 from castle. I just need some batteries and servos. I plan on running savox 0231 waterproof, making This truck fully waterproof, I see castle does not recommend operation while submerged.....all you bashers out there are there any concerns when running a "full waterproof" truck??
#606
Dry your batteries and electronics immediately after use with compressed air and I used dielectric grease on my terminals to prevent corrosion. Also the fan on the MMM2 is not waterproof so make sure you remove it before getting the ESC wet.
#609
for those who are looking for a nice body with a perfect fit the jconcepts ford raptor #jlo0084 is a great fit. this is made for a slash but it fits nice on the short 12 inch wheelbase maxx's the wheel wells are large and work perfect with large monster tires with no trimming. I would post a pic but I'm new here and they tell me I can't because I have not posted enough yet. how many do I need?
#611
Hi guys I'm new here been a long time sense I messed around with rc's
First time with nitros.
So I bought a basket case, we'll it dident start out that way.
The thing ran real good with the exception breaks were gone.Got a Tmaxx 3.3 from a friend for 150$. Good deal? I thought so had a few upgrades,
But the dirtiest thing I ever seen so took the old air compressor to it and no good it was a compleat dismantle bear with me I've never done the before so now I have my work cut out for me wish me luck
#612
Oh yah the whole reason I posted any and all tips for a old noob would be appreciated as in upgrades and things to look out for already got the RPM arms I just want to bash and have fun when I'm not working
#613
I just built and all most done EMaxx from the ground up, FastLane machine chassis (looks killer) rpm all the way and big bores, steel cvds. I also looked up how to shim the diff's and they needed that from what I bought off the shelf.
#614
Lots of maintenance running in water. Bearings, screws, and every other metal part will rust. CVD pins will rust and cause breaking on the rust spots. I coated my Savage XS in WD-40 for winter running in the snow.
