tmaxx problem
Old 12-27-2001 | 07:26 AM
Default tmaxx problem
i have a problem with my t maxx. i have the stock pipe on and after i run the truck there is a puddle of gas on the chassis. i know its from the pipe because theres a small gap in it. i have tried assembling the pipe back together and it looks sealed but it still leaks some gas. i know there will always be some fuel around on a nitro vehicle but this is more than usual. does ne1 know what i could do. thanks
Jarrod Langlois is offline
Old 12-27-2001 | 07:30 AM
TPhalen's Avatar
Well, it might be a different problem. If you seal the pipe, it's still gonna come out of the exhaust tip. You could use plumbers tape to seal the pipe.
TPhalen is offline
Old 12-28-2001 | 09:50 AM
ya i forgot to add i had to mess with the needles because of the cool fall weather. so im ganna try leaning it out. until i buy a new pipe ill try ur tip thanks
Old 01-14-2002 | 10:11 PM
If it isn't coming from the pipe, you might have a loose coupler that is leaking fuel out. The most common one I have seen is not putting a gasket between the motor and header after taking it off. That is sure to make a hell of a mess.
KerryG is offline
Old 01-29-2002 | 02:13 PM
Pull your pipe apart there is a baffle inside. On mine the baffle melted causing a constriction which made it pull more fuel than it could burn. I pulled the baffle out and end of problem.
born2burn is offline
Old 02-05-2002 | 05:24 AM
Default COUPLER
I had some trouble on the inlet to the exhaust. The metal actually got so hot, that it melted the plastic. Makes sure nothing is melting on you. And, yes, get a new pipe ASAP, you'll be very happy.
t-d-motorsports is offline
Old 02-09-2002 | 09:28 PM
i have a nitro rustler and had a similar problem. the metal 'header' got hot and burned the cable tie connected the pipe to the metal coming out of the cylinder. mine didnt leak gas, but smoke comes out heavily.
ryan type R is offline
Old 03-18-2002 | 06:45 PM
Default The pipe
I used to haev that promblem. first try to find a hole in the pipe or anything like that if that dos not work then you should try to take te pipe out and there will be a screw in the back of the pipe just titen it and you are all set
audi_711 is offline
Old 04-13-2002 | 06:52 AM
ya i screwed the pipe back together real tight it work better now.thanks
Old 08-21-2002 | 10:22 PM
fireblade's Avatar
Uhh try this, Pull off your header and do you have your Gasket still in there? IS it in 1 peice. This is a common problem with T-Maxxes the gasket is either missing or it broke in to a few peices.
fireblade is offline
Old 08-23-2002 | 08:21 AM
myclod's Avatar
Also Check where the header tube is welded to the Header flange....i have seen TINY pinhole leaks there before that cause problems
myclod is offline
HTML code is On
