.18tm issues
Old 01-24-2007 | 05:37 PM
nbcaznmaster's Avatar
Default .18tm issues
i cant get the carb off. I removed the nut and started pulling away. No luck. Put some wd40 in it and it still wont budge.
nbcaznmaster is offline
Old 01-25-2007 | 12:31 AM
Drift_Buggy's Avatar
Can you move it at all? As it move it around?
Cheers
Drift_Buggy is offline
Old 01-25-2007 | 09:52 AM
i can turn the carb easily. But it just wont move up and out of the crankcase
Old 01-25-2007 | 10:03 AM
AcadDude's Avatar
tap the pin over a bit....if you can spin it then the pin that clamps it down needs to line up right. the pin has a radius cut in it that is the same as the carb. get it lined up and you should be in business.
AcadDude is offline
HTML code is On
