Like Tree5Likes
My Old E-Maxx
Old 12-31-2020 | 07:54 AM
macr0w's Avatar
Default My Old E-Maxx
I just pulled this thing out of the shed after it sat there collecting dust for over 10 years.
I forgot what a beast this thing is.
Fast Lane Chassis
GA bulks
GA diff cases
Titanium skids (I forgot who made them)
Unlimited Engineering steering
Hitec 5955TG steering servo
All aluminum gears for the 2 speed transmission (I forget who made those too)
All steel shafts and CV's
Oversize wheels and tires
Everything else is RPM
So, I need a motor and ESC combo.
I'm thinking of going 6S this time. If I remember correctly a lot of guys at the track were starting to go 6s when I was getting out.
Better run times and less fires from what I understand.
We had lots of fires back in the day with the crazy mods we did to the old Mamba Max to get it to run 4s in our converted 1/8 scale gas buggies converted to electric.
I was going to try to run two 3s packs. I need to refresh my electrical/battery knowledge. I can't remember the whole series or parallel thing.
So I need a motor/esc combo that will support 6S lipo batteries
Anyway, I'd appreciate any comments or advice to help me get this thing rolling again.
xirton likes this.
macr0w is offline
Old 12-31-2020 | 10:12 AM
macr0w's Avatar
Hopefully my old Hyperion charger and blinky will still work okay.
I still have my Futaba T3PM that seems to light right up like it's ready to go.
I also took the Castle 2200 and mamba monster from my truggy.
Not sure if it still works actually and I don't have any batteries to test it.
Maybe I should just buy a couple of 3s packs and wire them in series and see what it does.
What is a good 3s battery to buy these days?
macr0w is offline
Old 12-31-2020 | 10:16 AM
macr0w's Avatar
I also found this old cage for the 3906. Remember these?
I forgot the name of the guy that made them.
Mine broke/cracked in a couple of spots.
I thought about making a custom crawler out of this thing for years but I never did.
macr0w is offline
Old 12-31-2020 | 11:17 AM
elk
I believe RC Raven made cages, although that one pictured looks like it might be an old New Era. Your setup looks like a blast from the past and brings back some memories. For batteries, I would order some SMC's or some Turnigy packs if you are on a budget. These will get you back to rolling quickly. Everything else should still work (I used one of those Hyperion chargers as well). Remember to keep track of which pack you use per side and alternate them each run/charge cycle.
elk is offline
Old 12-31-2020 | 12:08 PM
the rc guy's Avatar
series is 6.. parallel is 3 just more run time n less rpms...looks like a well LOVED rig.shelf queens are a great awakening. Glue and lube..
the rc guy is offline
Old 12-31-2020 | 02:57 PM
macr0w's Avatar
Here it is before I cleaned it up.
Definitely well loved bitd.
macr0w is offline
Old 12-31-2020 | 03:24 PM
macr0w's Avatar
Can anyone refresh my memory on the thread pitch on the slipper clutch on the 3906?
There is 32p and 48p which I understand. But, what is Mod 1? I remember the term but I don't know what it means.
I need a pinion that will fit on the bigger shaft motors. 5mm?
I have a few with the right pitch but they have too small a hole to fit the shaft of my 2200kv Castle.
I also have a few that fit the motor but not the right pitch for the slipper.
Thoughts?
macr0w is offline
Old 01-01-2021 | 04:42 PM
macr0w's Avatar
I also had this in my Truggy.
macr0w is offline
Old 01-01-2021 | 06:41 PM
8711 used to be my favorite servo back when racing monster trucks was a thing
biglor is offline
Old 01-02-2021 | 05:57 AM
macr0w's Avatar
This servo came out of my E-MBX5T that I use to race.
I use to have an MBX5 setup for going fast in the street and an MBX6 for racing.
They are awesome vehicles.
biglor likes this.
macr0w is offline
Old 01-04-2021 | 12:44 PM
macr0w's Avatar
So is the Traxxas slipper clutche on this thing a 48p or 32p?
macr0w is offline
Old 01-04-2021 | 09:05 PM
Default Spur
I looked up the manual.... got a part number for spur (optional) 5969 or something. Then looked up that part number and in the description is says "mod .8" it also showed mod .8 on the side of spur in the photos.
best i can do. ( and it could be for the nitro version for all i know)
good luck!
macr0w likes this.
jchammbone is offline
Old 01-07-2021 | 02:08 PM
Suspended
There's conflicting info about this online, one site says it's 32dp, the next says it's Module 0.8 and so on.
The two are really similar though and most people say there're pretty much interchangeable with 32dp being Module 0.7938 or the other way around Module 0.8 being 31.7653dp.
kawasaki161 is offline
Old 01-08-2021 | 09:15 AM
Biz73's Avatar
I've run 32p pinions in my .8 mod Tamiyas for a few years now without issues.
macr0w likes this.
Biz73 is offline
Old 01-08-2021 | 05:20 PM
Original was 32p.
macr0w likes this.
AZKev is offline
