t-maxx shift problems
my t-maxx 2.5 will not shift into 2nd, even when i let it rev to its limit, it doesnt shift. i have adjusted the screw for the shift point, and it does nothing! the thing was, i was driving it a few days ago, and the shifter worked! am i going to have to take the transmission out, and fiddle around with the gears? i have not overtightened or overloosened the screw.
thanks!
thanks!
well this can actually be alot of problems....
crushed spring,broken clutch engaging notch,engine tuning i suggest u tune ur engine correctly and then pull apart the tranny and lookat the 2nd gear closely
i just ripped the tranny apart, for the first time, and this isnt as complex as i thought it would be. i see the gears, the smaller one is supposed to move freely, right? i checked the spring on the 2nd gear , and it looks fine. what would happen if i removed the screw/spring completely? would it cause both gears to engage, and shred eachother? i havnt tried tuning it to its best, but i rev it MUCH higher than it usually took to shift, but it doesnt. i am puzzled.
if there is anyone who is experienced with these trannsmisions, i may trade this stock one , with another working stock one, for a deal! i am tired of this!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
no no no NO NO the spring is not bent from a jump!!!!!! its from overtightening !!!!!!! does it look dimented?? its from overtightening man never ever tighten a spring more than 1 1/2 max 2 turns from factory position !
