Emaxx blown diffs!  Multiple. >
Like Tree6Likes
Old 02-15-2018 | 05:08 PM
  #16
ddd228's Avatar
Cannot find::: K maxx diff cases.
I need ALL of the parts to build a rear differential.
I don't like the alloy bulkheads at all.Yes,I have chassis twist.
I don't even have a plastic diff in my stash anymore.
ddd228 is offline
Old 02-15-2018 | 05:37 PM
  #17
ddd228's Avatar
I can find Integy cases.NOT Kmaxx cases. Integy rear case on my truck,now.
There used to be "Snoopy" here.snoopmaxx
We got along fine. Not to say that we don't get along. I play nice.
I'm on 5 forums and I never flame anyone.
ddd228 is offline
Old 02-16-2018 | 08:30 AM
  #18
Blazerss is (one?) of the guy(s) behind KMaxx Kustoms.
https://www.rctech.net/forum/members...rss-72621.html
Kmaxx Kustoms hopups
https://www.facebook.com/KmaxxKustoms/
Overdriven is offline
Old 02-16-2018 | 02:24 PM
  #19
ddd228's Avatar
Thanks! I PM'd him with questions. I don't do Face book.
ddd228 is offline
Old 02-16-2018 | 09:52 PM
  #20
ddd228's Avatar
Cool FLM's.
Originally Posted by xirton
I have a set of FLM Ultimate Hybrid Bulks if interested. New condition.
I'll buy these!
I bought them.They have to come from across the pond.
ddd228 is offline
Old 02-17-2018 | 01:18 PM
  #21
Hybrids are dope, now you only need a center diff hehe.
FunnieKid is offline
Old 02-17-2018 | 01:23 PM
  #22
ddd228's Avatar
Default Center diff?
I won't bother,but I'm glad that I have a slipper.(At least.)
Unknown weight of diff oil is inside.
ddd228 is offline
Old 02-24-2018 | 05:10 PM
  #23
ddd228's Avatar
Questions?? 11 mm out drive boots?HPI? Losi? Hobao? Ofna?
Next question: What do I use to protect the out drives if the out drives on the diff has 11 mm diameter ones?I have used fingers from rubber gloves B-4 but they go away if a LITTLE oil gets on them and they are terrible against UV rays from the sunshine. I have made ones from shrink tube and they work only fair to keep dirt out.
I found REALLY good ones for my 1/10 scale: Durango ones.
I'll be using CVD/dog bones.
Some 1/8th scale ones will do,I guess.
I should have some for the center shaft as well.
Monster R/C is out of the good stuff!
ddd228 is offline
Old 02-25-2018 | 07:24 AM
  #24
Why do you want to protect them? Dirt will always find its way thru as well as water and then it will rust. I always spray some wk40 in the cups to prevent rust and add some lubrication.
ddd228 likes this.
Old 02-26-2018 | 12:40 AM
  #25
ddd228's Avatar
Questions?? Out drive lube? Protection?
That stuff will actually attract dirt.Grease? NOPERS.
I have used graphite lube B-4,but it flies off.Bicycle chain lube based on WAX is OK. I would rather seal it off from the dirt.
Recommendations?
I just don't want my out drive cups to get eaten out/oval looking.That condition may cause some weird suspension issues,IMO.
ddd228 is offline
Old 02-26-2018 | 01:08 AM
  #26
ddd228's Avatar
Cool Chassis twist?
Originally Posted by the rc guy
id go with the diffs in post 2..and brace the chassis so twist is less..
I get your concern and YES,there is a chassis twist!
I will address that issue when I have it all apart.(NOW).
Braces? Yes.
I'll get some ideas soon. Thank you for that caveat,Sir.
If it wasn't for this community,I would be lost in space.
The RPM towers and bulkheads are very squishy!
Perhaps the FLM parts will help a lot. No,they will.
ddd228 is offline
Old 03-01-2018 | 06:55 PM
  #27
ddd228's Avatar
Talking FLM hybrid differential discoveries!
#1: Out of the "box" the pinion depth was ALL wrong!
#2: There is a place for a dowel alignment pin. I made one.
#3: The supplied input is much longer than I needed but FLM had some shorter ones w/8 mm shaft size!
#4: The supplied diff case bolts are way to short.I'll dig in my parts stash.
#5: The diffs were not greased very well on the ring gear and the happy part was that each diff had way different silicone diff oil installed. It feels like 10 K and 5 K fluid.I'll run it as I feel like it.
Dowels:It's already machined into the case and I used a 10th scale Lunsford camber link and made 2. The actual size of the alignment dowels is 3.18 mm.
The side to side diff clearance was fine but NOT the pinion depth.See pix.
I ordered the shims last week in anticipation of the need.13 X 16 X.2 mm a bag of 10! Required!
This diff has a spiral cut gear set.Unknown brand. Ideas?
Overall,this is a very high-quality pair of units. It is like jewelry!
" target="_blank">
Input drive cups:
Click pix for a larger view.
The next question is HOW I can build center drive shafts for this creation.
I would prefer to use splines shafts to make it easier to work on.
I had the correct length one for the rear,but not the front.
I was using plastic drive shafts and I never snapped one. I use MIP CVD steel ones for the shafts to the wheels.
I still need protection boots for the out drives.The shrink tube still lets dirt in there.Suggestions? The out drives are 13 mm in diameter.
Internet descriptions do NOT give the sizes or dimensions of the boots that I will need/want. WL Toys has 'em but they come from Taiwan.
The differential shimming is REQUIRED and I'm all over it.
Center drives?
It looks like I have the rear one figured out,with the shorter FLM input cup:
No,I won't fix my typos.
" target="_blank">
ddd228 is offline
Old 03-01-2018 | 07:07 PM
  #28
ddd228's Avatar
Pix are WAY too large.
ddd228 is offline
Old 03-02-2018 | 12:17 AM
  #29
the rc guy's Avatar
you can dl a pic program like.faststone .4 computer to resize pic
the rc guy is offline
Old 03-02-2018 | 07:56 AM
  #30
xirton's Avatar
Dave, diffs are from Kyosho.
That's a gnarly looking truck dude - love it!
Is this the one you built with Dan Fischer?
xirton is offline
