SJCCR at Wagner Park 2014 "Counter Clockwise Edition"
#31
hmmm.... I'd love to get a 5th scale, but considering how much I've raced in the last few years, probably not in the cards
not sure if I'll be down for opening day (daughter's softball schedule), but definitely plan on being out a couple of times..
any thought about running a USGT class?? with or without the spec tires
Note: JANUARY 1 2014 The Ride spec tire will become the official spec tire for USGT
RIE24025 - set of 4 available through Gravity RC http://www.teamgravityrc.com/ to dealers and retail
Chassis Specification:
Any 1/10 4wd or Fwd sedan with 4 wheel independent suspension.
Weight Specification:
4wd 1450g weight Fwd 1200g weight
Body Specifications:
Any 190mm or 200mm body. Body can be any body that is NOT on the ROAR T2 body list. FWD encouraged to use FWD bodies However, Can AM or IMSA style bodies, similar to 1/12 or 1/8 bodies are also discouraged NO Trucks
Any "SCALE" molded wings can be used. Lexan wings 10mm maximum height / side dam height
Scale type race liveries encouraged
Tire & Wheel Specifications:
Tires- RIE24025 - set of 4 available through Gravity RC http://www.teamgravityrc.com/ to dealers and retail
Grinding of tire tread is NOT permitted. Sanding of mold seam to remove seam is allowed
Wheels- Any 24 or 26mm spoke (non-dish) type wheel
Ride Height Specification:
Minimum ride height is 5mm.
Motor Specifications:
ROAR approved 21.5 + 2s lipo batteries No tuning rotors, must use OEM rotor 12.3-12.5mm
Approved ESCs:
ESC ROAR approved spec software or USVTA list
Race Specification:
6 minute qualifiers
8 minute mains
Battery Specifications:
ROAR approved hard case batteries
Approved ESCs:
Race Specification:
6 minute qualifiers
8 minute mains
#33
Thanks for the phone call today Marco. I fabbed up a servo bracket today at the shop. Now Ive got 2 Hitec 5805MGS in the car. Problem solved. This weekend Im going to overhaul the car and get the alignment done. Looking forward to running the car next weekend with you and Carlton. Let me know what day to meet up. Saturday would be great if the weathers good. Im gonna try soaking my P- Supreme tires with WD-40 this week for running at BD. The stock tires should be fine for WP.
#34
Anyone want to run Monster Trucks?
#35
FYI, I will be out of town again on Saturday, so Sunday will work better for me....
You guys are more than welcome to go on Saturday, but the track will be hella filthy unless you bring blowers....
If you go on Sunday, I'll bring the track blower and generator....
#36
#37
I'm assuming that controlled pratice sessions will be implemented, since smaller cars will be running counterclockwise and larger cars clockwise... Controlled practice probably wouldn't be a bad idea if all cars were running in the same direction, now that I think about it...
#39
I would love to run gt1/8e. Anyone else with me?
#40
Who is in, for which day, this weekend so others may join you....
If anyone is planning on Sunday, I won't get there till 2pm....
#45
