mini revo help
Old 02-11-2012 | 09:05 AM
Default mini revo help
i bought a mini revo and i'm wanting to get backflips and go at least 50+mph i'm currently running two 2s 20c lipos in parallel and im getting 40mph and no backflips and i know the merv is totally capable of doing both what setup should i try and what batteries should i use thanx
cdog2508 is offline
Old 02-11-2012 | 03:07 PM
MrUnlimited's Avatar
Why not add wings to your revo?
MrUnlimited is offline
Old 02-11-2012 | 03:11 PM
Talking
lol yea sure
cdog2508 is offline
Old 02-11-2012 | 10:33 PM
Dhthmn114's Avatar
You can run them in series with a series connector... It will split your runtime in 1/2 while doubling your power output... But unfortunately on these little guys the diffs cannot handle that kind of power output... WAYY TO MANY of us found this out the hard way...
1/16 E-Revo = 1/16 E-diffshimminsonofa*****...
Dhthmn114 is offline
Old 02-12-2012 | 05:30 AM
BashemSmashem's Avatar
Wont do it on 2s batteries , you need 3s .
BashemSmashem is offline
Old 02-12-2012 | 08:25 AM
Roadbeaver's Avatar
11.1v 3s will do backflips with ease, but why do ou want a 50+mph back flip....it will break...often
Roadbeaver is offline
Old 02-14-2012 | 01:32 PM
Drex1971's Avatar
I think he means he wants to do standing back-flips from a standstill and still be able to go 50+ all with the same set-up. 3S with the speedgear installed should do this.
Caution: do NOT run a pair of 2S lipo in series (4S) unless you want your esc smoked. The stock esc cannot handle 4S. Series is only for the stock NiMH's on the vxl3-m. If you want to run 4S (insanity in a Merv), you'll need to step up to a 1/10 scale esc that is rated to handle it.
Drex1971 is offline
Old 02-14-2012 | 09:10 PM
i don't wanna do backflips @ 50 mph that's crazy i wanna beable to go 50mph and while im at a stop do backflips
cdog2508 is offline
Old 02-14-2012 | 09:30 PM
You can always go big block (PM me if you want a NIP tenbol mount). I did that with my MERV and could do backflips easy. Plus with the bigger motor, you get no heat problems.
skyrider is offline
Old 02-14-2012 | 09:51 PM
where can i find a big block motor and if i got the bigger motor won't it kill my diffs ??
cdog2508 is offline
Old 02-14-2012 | 10:21 PM
You would be able to run any 540 motor.
I personally ran a castle cm36 5700kv since I found one used for a good price (Don't really need 4pole as that will just give you excessive torque). That gave me really good power and speed. I was always light on the throttle and was rarely ever at full throttle unless I had a lot of space (which I don't at my local park).
There are cheaper options though like a TACON motor or a hobbywing one.
If you shim up your diff's properly and adjust the slipper well you won't have diff issues. I personally shimmed up my diffs and never had issues. I also had a castle ESC that allowed me to limit torque and things too.
My advice would be to pick up a hobbywing system. It is cheap and very customizable in terms of setting. Or maybe find a cheaper castle system (sv2 or sct + 540 motor.
skyrider is offline
