Tire Options for 1/16 Mini Slash
#31
Please read the forum prior to posting next time. As far as your rude, irrelevant comment "Not sure why anyone would want a mini slash", there is no need for comments like this. The reason I started this thread was because I could not find a forum thread that specifically talked about ONLY the 1/16 slash tire options.
#33
Agreed I'm really sorry for not posting my mini slash pictures this weekend. I had my digital camera out and took some pics, but alas work had to take priority once again.....sigh. I will try to post this somepoint this week, since I believe if we get more pictures in the thread more people will post their mini slash setups.
#34
I saw some Kyosho mini-pins on the Toyz site that I think look good for my Mini Slash Buggy. Otherwise I like the HPI Soft Rally tires or the Vintage tires. HPI offers a large amount of wheel options for these tires. The Mini-Revo should have tons of tires. just choose any 10th scale 2.2 buggy tires. The Mini Slash is limited to the 10th scale road tires.
#36
I can say for sure the Team Academy SB pro 4wd buggy wheels (then use any 4wd buggy tires) are a direct bolt on for the Mini Revo. They have a considerably narrower offset, but I would think you will have body rubbing issues with a Slash.
#37
the Mini Inferno Buggy wheels/tires will fit and work great, you have a whole selection of tread patterns and wheel style to choose from
You will need a set of Mini Inferno Hub adaptors as they are not 12mm....the Mini Inferno is like 8.6mm...anyways, slightly open the axle hole in the wheel up a little, add the hexes and they bolt right up.
About 1-2mm shorter, same width, same offset.
Installed on my truck
#39
#40
I am using the Kyosho Mini Inferno aluminum hexes, same axle hole size, same pin mount, just a smaller wheel hex to fit the Kyosho stuff
#41
What would be a huge help here,for a newbie,,,,, how about some part numbers on these wheels and tires and the adapters,,PLEASE! thanks
#42
hi guys i just put my mini lst tires on my 1 16 slash they fit and have all steering all you have to do is replace the traxxas wheel hubs and put the mini lst ones on and then drill out the inside of the wheel so it will fit on the axle i know this shouldnt include any modding but it really doesnt hav to mod any part of the truck here are some pics
#43
Attachment 587897
Attachment 587898
Attachment 587899
Attachment 587897
Attachment 587898
Attachment 587899
#44
well i havent gotten to try it out yet but i have the double black springs and it never gets low enough to get close so im waiting on some axle cariers and then i will try them out and post a reply. ps the double black springs are the greatest 3 dollar upgrade ever
#45
FYI - I do still have the stock oil in the shocks.
