Kyosho Mini-Z Series
#6631
Thanks. Yup, right on...the axle carrier was cracked allowing the axle to spin freely. I was able to push down on the top suspension arm plate MZ406 which held the axle still to remove the wheel nut and wheel. Added a drop of CA glue into the cracked area for a temp fix. Who knows how long it’s been running like that without me even knowing lol
That happened to me twice in less than 2 weeks I took the knuckle and put some glue around the axle. Before it dried up I made sure it went in between the plastic and the metal axle. Once it dried up I hold the metal part with a needle nose plier. Between the plier kinda slowing it and the glue. I was able to get it out. Once out. I put more glue on the other side of the axle. So far so good. But I’m pretty sure it won’t hold for too long
I used gorilla super glue.
#6632
#6633
Over 2,000 laps on this set on current layout.
#6634
Well i might buy 1 awd and 1 rwd. How is awd on track?
#6635
The disk damper system is a huge improvement over just a t-plate and top shock. There are spring loaded disks below and above the damper plate. It provides a lot of stability in all directions and lubes can be used to dampen/tune the rear end. A+
You can see my latest build using the MM2 HERE
#6638
#6640
It was a surprise to me on how snug the batteries fit. I dont have a solution to charging inside the car. But since Im just running for fun inside the house, I left the battery holder clips off. Don’t recommend this if racing though.
Using a small flat screwdriver I’ll remove the batteries in 1 of 2 ways. One is to lay the the screwdriver on the + end of the battery and push against the tab where the - side is and pry up at the same time. Gotta be careful not to tear the casing of the battery.
Other way is to push with the screwdriver from the underside through the openings; I usually have the screwdriver more towards the + terminal.
#6643
I have been using one of the tools that came with kit to pop the battery out from the chassis underside. Seems to work.. Shame one of those JST plugs on top of chassis can't be used as a charge jack.. would make things nice!
I have to say I am impressed with the kit tyres that came with the car.. My son has been driving his MR-03 Nissan GTR on the hard wood floor.. they offer very good grip. I recall my MR-01 years back.. would just spin out.... which resulted in my buying the MA010... I was initially tempted to go the AWD route again.. now I see no use for it.. So they have come a long way.
I need to make my way to Home Depot to buy some grey Ozite for the track I'm going to build in the garage.. hope I find the right one available locally..
#6644
#6645
Once you get the stock tires on RCP track. Or try a better set. You’ll see the difference. I ran the stocks for 2 months. Then went to the group I race with. Could not even run a lap on the smooth side with them. One gave me a few worn sets that improved my FWD and RWD by over a second a lap at home.
also.. can someone tell me what this little tool is for?
