Kyosho Mini-Z Series
#3587
Anyone else have rubbing issues with the McLaren P1 GTR and the 1.5mm offset front wheel it came with? I’m using the Kyosho radial tires. 1.0mm have no issues.
#3591
Just a heads up. Front and rear are different width. So you need to buy set of rack.
#3592
Kyosho 30 front/20 rear is a good base setup. I have been preferring PN soft F-type and firm or medium front tires for stock classes on the smooth side lately. The traction on the smooth side is more similar to that of the EVA foam tiles that many make their home tracks with. The RCP has more traction, but similar. In general, I prefer radial in rear and slick in front.
#3594
Update.
Just read this helpful webpage. Was probably written by someone in this thread. I'll order those tires, the pinions and the tape. I'll pass on the chassis plate and bearings for now.
I would also add a disc damper if they have it in stock. The disc damper I feel is the biggest upgrade for these cars.
PN disc damper
#3595
What are you all using for lap counting at home? I'm aware of some free computer software that uses a webcam. I've watched some video of lapmonitor which appears to be very convenient and portable. Lastly I've seen an phone app that use the built in camera to count cars, similar to the older computer lap counter.
#3596
I think most use the EZ lap system.
#3598
The Zeppin system comes with a 1/10 sized transponder. They do have Micro/MiniZ sized. But have to be bought separately.
#3599
#3600
Cheers,
Jim
