Kyosho Mini-Z Series
#2866
#2868
I didn’t realize that some actually ran without rear shock until recently. Always thought there was a reason it was off in pictures.
#2869
I usually race without a rear shock. I also only use one disc on the dds.
Just try and see what works best for you and the track.
#2871
My mod with only top disc.
Needs more on-power steering. But I can throw it into any turn as hard as I want.
#2872
Cheers,
Jim
#2873
I now.
The feeling when you master black magic is almost second to none ;-)
#2874
https://docs.google.com/spreadsheets...2GY/edit#gid=2
Body Specifications ? MINI-Z Info
#2875
One of these links might Help.
#2876
So far stock has worked just fine. It’s really all I’ve ever driven in my limited time with this scale. . I’ve only tried once driving one that was a full PN car. I couldn’t judge the car because I didn’t like the odd feel to the controller.
#2877
have you played with springs at all or are you really totally stock?
cheers,
Jim.
#2878
Around here, many racers use only the lower damper disc. Which provides a lot more steering, both on throttle and off. I almost always use two discs if I can fit them. I typically preload my upper disc more in faster motor classes to gain more rear traction. I also often use a top shock.
The single lower disc will allow more droop (when not using a top shock to limit it). which gains more front end traction off throttle due to weight transfer forwards being less restricted. On throttle, a preloaded lower disc will give less rear traction therefore more steering as well. I like a relatively neutral rear end, which allows me to drive the car harder. A single disc doesnt give that to me. I feel that the car will have more variance in line and react too aggressive with certain input levels. I have never tried a single upper disc though... which seems like it would give a very calm car, with a pushy nature. However, that could be compensated for with a very aggressive front end, as you will ride the front end in to the corner harder, and have loads of traction coming off the corner.
#2880
I try to experiment a bit with setups and modifications. To try and find what works for me.
My Superstock (5500kv on nimh) has got a std PNR 2,5 with only disc under.
The mod was a project of getting a very low CG. This made it impossible to fit a disc under. So then I went disc over with extreme tire wear and a lot of maintenace as a result.
During a race night with practice, three quals and tripple A-mains I go through a couple of Marka V5F15 fronts. I have to rebuild my diff before last qual and i have to butter up the disc before each heat.
The car is crazy fast for my drivingstyle, but the setup window where it works is minimal.
I have now raised the carbon plate a few mm to get a disc under and to find a more ECO-friendly setup. ;-)
The plan this weekend is to find a less extreme setup that is just as fast and consistent.
Really have to lower my tire-budget :-)
