Kyosho Mini-Z Series
#1771
It doesn't sound like the board. if you can enlist another hand to work the throttle while you wiggle motor wires at the motor end. After that or before, spray the motor thoroughly with the cleaner I mentioned several post ago. With the stock motors a spritz of motor spray after each use will go a long way toward longevity as well as trouble free operation.
#1772
Motor spray in the stock motors is a must... at least once per day use, and a little lube on the bushings. Never use comm drops.
you can test the motor by removing the wires from the chassis, and bridging them on a single charged aaa cell tp ensure that it works properly.
if the motor works, screw back into the chassis and double check the connections. If the motor does not work, then the large "fuse" may be causing issues. I remove it from all of my stock motors by default.
#1773
Greetings,
I’m purchasing my very first unpainted Autoscale Body - a Honda (Acura) NSX. I’d like to add a spoiler. Does anyone have a thread I can review for how install a spoiler from scratch. Plus does anyone have a suggestion on where I can go and purchase a spoiler?
Thank you all for your support for newbies like me.
#1774
I just have to write a note and praise Kyosho USA for their fantastic customer service. They were super responsive from the first note I sent them. They offered to send a call tag to pick up the defective car and I told them about my situation and the fact that I currently did not have a box to ship it back to them. Just a few minutes ago I received a e-mail saying that they are sending me a replacement as well as a shipping label to send the old car back in the box that the new car is coming in. I mean that is some awesome service and not typical in this day and age. Two thumbs up for Kyosho USA.
Cheers,
Jim
Cheers,
Jim
#1775
I need a little help. Bought 2 MR-02 cars. 1 bone stock, works great. The other has a PN racing 33T motor, aluminum motor mount etc. When I first got it the motor was a little slow to respond but would. Now throttle is totally gone. It will sometimes go reverse if I mess around a while. Tried the other radio and same behavior.
Removed the motor and used a AAA battery and it runs forward and reverse.
I did discover the leads were loose, screwed those back down.
Small antenna broke off the solder pad, re-soldered that too. But same behavior. 1 question. Does the little antenna attach to the solder pad next to the Antenna hole on the board?
Any other options? Is there a replacement board?
#1776
Odds are good that you have damaged the throttle circuit on the board unless it had been previously modified to accept that "hot" of a motor. Depending on the age and production run for the board the stock mosfets may not be up to it, Carefully remove the top cover and see if you can read the number on the fets. If it is marked 3004 it won't pull that much motor especially if it is over geared. If they are marked 3010 you may be able to get by with it as long as you don't put too large a pinion on it. Personally I wouldn't gear that motor any higher than 4.88
#1777
Thanks for the reply. I bought these used, so will check the fets. Would the board be toast or can it be repaired?
#1778
Fet's do say 3004, so I may be out of luck.
#1779
Are these by any chance "AM" cars or the later 2.4? If they are AM it isn't worth repairing what appears to be a burned board. Just purchase a later model "410" or Tiki-Tiki 03 board. Keep the existing steering servo motor and solder it in when you swap out the board. This brings up transmitter concerns but you can get by with a Kyosho KT 18 radio. Or the other option would be to ditch the 33T or use it to pin notes to the refrigerator and replace it with something a little more sane like a PN 70T. Then you should be able to find someone to replace the fets and keep what you have.
#1780
I think I may just get one of the new ones. The McLaren can be had for $130. The boards are pretty costly from what I can find. I appreciate the help!
#1781
Pn pot?
Hi all,
New here, been racing mini-z for a while now, and I went with the flysky FS-IT4S radio, but I am disappointed in the steering travel. I tried a friend's KT432, and it was MUCH better, but I just read something here about replacing the servo pot with a PN racing one. Does that really make a difference? Is there any way possible to make this radio use the kyosho firmware, or another trick I'm not aware of? I can't swear to it, but the car may have been faster on the kt432 also. I know my lap times dropped a couple tenths without me really having the settings where i liked them, nor enough time to get user to the radio. Overall, I feel the flysky was a mistake.
#1782
There is also the option of the Das Mikro board from banggood. A 2.4 board that you transfer all your support pieces(switch, pot, servo motor) to the new board. They are under $50 and work quite well.
#1783
Hi all,
#1784
There s a setting in the radio that will correct this concern. It appeared when the radios were first introduced. It has been so long that I can't remember what it was, my suggestion would be to contact Flysky for the solution. The two radios are essentially identical except for the fact that the KT432 will convert for left handed use,
#1785
That is an option as well but the board still won't accept that motor. If you can get on the PN site you will find a list that describes each of their motors and what electronics are needed to support them.
Is this the dasmikro board?
The motor I am not tied to, I got these both cars for a good price, so just trying to get another running so I can race with my daughter.
